E-brake light on/off
Discussion in '1st Gen Tundras (2000-2006)' started by jjTundra2007, Oct 4, 2020.
  1. Oct 4, 2020 at 3:21 PM
    jjTundra2007
    jjTundra2007 [OP] New Member
    Silver 2007
    Hey everyone,
    May I ask you for help And some tips...my tundra 2007, the e-brake is randomly on and off while driving.We have changed switcher , reconnect broken cable But still light comes on and off.
    Any other suggestions? New master cylinder, should be leak as fluid is normal.
    Thanks for any advice.
  2. Oct 4, 2020 at 4:58 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    bmf4069 likes this.
  3. Oct 4, 2020 at 5:05 PM
    fairclothr1
    fairclothr1 Here and There Member
    Ryan
    2009 Sand Mica Tundra TRD
    Plasti Dipped grill and badges. Shorty antenna.
    Check your brake fluid level. I had that happening and added a little fluid and it went away. Do not add much, as your brake pad wear lowers the level, so, if it's low, check your pads. May need to change them, and if you add too much, it could overflow when pads are changed. Cheers!
    radon222 and BigBone001 like this.
  4. Oct 4, 2020 at 7:44 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sounds like fluid level to me. Probably time to do pads
    radon222 likes this.
  5. Oct 5, 2020 at 10:57 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  6. Oct 6, 2020 at 10:30 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Man I get a chuckle with this and the shoo memes
    bmf4069[QUOTED] likes this.
  7. Oct 6, 2020 at 11:38 AM
    jjTundra2007
    Silver 2007
    Pads are still good. Added tiny bit of fluid and so far so good works as should be
