E- brake cable slack
Discussion in '1st Gen Tundras (2000-2006)' started by Deslock23, Mar 7, 2019.
  1. Mar 7, 2019 at 2:20 PM
    Deslock23
    Deslock23 [OP] New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
    how much should there be? Brake works fine and it’s not what I’d call dropping, just seems a bit more slack than I think it ought to have. Here’s what I’m working with:
  2. Mar 7, 2019 at 2:21 PM
    15whtrd
    15whtrd Mr. Blonde
    I don’t have drum brakes on my first GEN sequoia but that doesn’t look right. I wonder if there’s a bracket that is missing. What does it look like when the E brake is applied?
  3. Mar 7, 2019 at 2:41 PM
    Deslock23
    With the brake applied it’s taut, but returns to slack once released.
    EFD23A06-75B6-4C2F-BEDD-BAAB58549F5C.jpg 958410D5-1635-44A0-96A9-92C7A65E5CC8.jpg 68B072BB-41AA-43BE-8047-A57FCFD25AFD.jpg
  4. Mar 7, 2019 at 2:46 PM
    15whtrd
    15whtrd Mr. Blonde
    Tundra2 likes this.
  5. Mar 7, 2019 at 2:49 PM
    Aerindel
    Aerindel New Member
    Montana
    Looks exactly like mine. I've been wondering if there is a way to adjust that side separately as, the drivers side is tight. I've just been tucking mine over the base of the brake proportioning lever as that holds it up out of the way and almost looks like it was designed that way.
  6. Mar 7, 2019 at 2:50 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    I'd suggest to adjust it, if still slack then zip tie it up and out of the way of potential snags.
  7. Mar 7, 2019 at 2:51 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m trying to figure out by looking at that linkage how it pulls on the driver side.
    Aerindel likes this.
  8. Mar 7, 2019 at 2:53 PM
    15whtrd
    15whtrd Mr. Blonde
    I think you should try adjusting it. Jack the truck up off the ground put it in neutral. Adjust it but make sure the wheels still roll without dragging on the emergency brake.
    Tundra2 and BestGen like this.
  9. Mar 7, 2019 at 2:57 PM
    Deslock23
    Thank guys, will have to wait til the weekend, it's been like that forever but I just noticed it again today and figured I'd ask.
  10. Mar 7, 2019 at 2:58 PM
    15whtrd
    15whtrd Mr. Blonde
  11. Mar 7, 2019 at 3:23 PM
    Professional Hand Model
    Hand Protectors
    There is a turnbuckle under the drivers seat under the chasis next to the fuel filter. Adjust the slack there.
    POC, lc69hunter, jpink and 3 others like this.
  12. Mar 7, 2019 at 4:37 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Just saw this. Now I gotta go outside n crawl under the truck. On second thought I'll have son #2 go outside and crawl under the truck. ;)
    Darkness likes this.
  13. Mar 7, 2019 at 4:45 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Dang we have the same rear shocks too!
    Mine isn't saggy like that.
  14. Mar 7, 2019 at 5:54 PM
    Aerindel
    Aerindel New Member
    Montana
    Exactly.
    Wouldn't that just tighten the brake system in general? My drivers side cable is tight, the passenger side is loose.
  15. Mar 7, 2019 at 5:58 PM
    15whtrd
    15whtrd Mr. Blonde
    Looking at the picture again it looks like the driver side doesn’t get pulled on until the passenger side is tight.
    Aerindel[QUOTED] likes this.
  16. Mar 7, 2019 at 6:02 PM
    Hand Protectors
    lc69hunter and Aerindel[QUOTED] like this.
  17. Mar 7, 2019 at 6:02 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Pull the wheels and check that your bell crank is actually moving. Mine did the same and the bell crank on that side was completely stuck.
    Deslock23[OP] likes this.
  18. Mar 7, 2019 at 6:02 PM
    Deslock23
    Update: Flexing my google-fu led me to check the bellcrank stops that the cables attach to, turns out my left side isn't hitting the stop and appears to be (at least partially) frozen, but right one is free. I can't do anything about it til this weekend, but it tells me what I need to do to fix it.
    Edit to state that @Festerw is a faster typer than I am.
    15whtrd and Darkness like this.
  19. Mar 7, 2019 at 6:09 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Deslock23[OP] and 15whtrd like this.
  20. Mar 7, 2019 at 6:13 PM
    Hand Protectors
    Everything I’ve ever tried with my parking brake has never allowed it to work properly. All my cables look good. Stops look good. Cranks work. Butt, p-brake will not activate when the pedal goes down.
  21. Mar 7, 2019 at 6:21 PM
    Deslock23
    That is odd, if the cranks are moving and resetting properly, it's got to be something in the drum. Honestly I never have bothered with an ebrake in an automatic, so I never noticed till tonight that when I engaged it it went all the way to the floor easily. I'll deal with it over the weekend, it's waited this long a couple days wont kill it (I hope).
    In all fairness I was able to get that drivers side to move a little, enough to where it seemed to cause the slack to come out a little on the other cable. But we are gonna play some roulette and see.
  22. Mar 7, 2019 at 6:21 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Are the short cables inside the drums still intact? Mine had the end loops but the cables were rotted off.
  23. Mar 7, 2019 at 6:27 PM
    Hand Protectors
    Not sure. I’ll be pulling the drums off soon to clean everything up. Had 2 different mechanics look and ‘adjust’ over the years on separate occasions with no success.
  24. Mar 7, 2019 at 6:32 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Yea I adjusted mine a few times then when I pulled it apart to do the bell cranks I'm like WTF are these doodles lol.
  25. Mar 7, 2019 at 6:33 PM
    15whtrd
    15whtrd Mr. Blonde
    I guess the saying fits. Use it or loose it!
  26. Mar 7, 2019 at 7:09 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Mine has a lot of slack too and my ebrake still doesnt work after finishing my rear brakes.
  27. Mar 7, 2019 at 7:49 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    POC, peanut, 15whtrd and 2 others like this.
  28. Mar 9, 2019 at 3:54 PM
    spyshot
    spyshot 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    Just fixed this on mine a few months ago...the turnbuckle under the door was not enough so I kept looking. it was that little arm on the back of the drum plate thingy...(terminology?) behind the driver side rear wheel. It was seized and not springing back. I couldn't even budge it with my hands. the passenger side was free but the driver's side was not. you should be able to push the arm and have free movement and it should spring back. i sprayed inside of that rubber boot from both the outside and the inside (after removing the wheel and drum) in order to free it up. had to tap it with a hammer too. I got it freed up and it took all the slack out. Then the turnbuckle under the driver's side door had to be let out, it was too tight.
    maybe that was the answer you already found on google, but I don't know what bellcranks are. :)
    bmf4069, Deslock23[OP] and 15whtrd like this.
  29. Mar 9, 2019 at 4:00 PM
    Deslock23
    Thanks for the update! I need to have my brakes redone anyway so while I am off the next few days will get this and my windshield taken care of (that 15* day we had last week did it in)
  30. Mar 9, 2019 at 4:19 PM
    Aerindel
    Aerindel New Member
    Montana
    Mine works great, but is loose like that.
