E brake cable rubbing bed mount
Discussion in '2.5 Gen Tundras (2014-2021)' started by 18tundrasport, Dec 31, 2017.
  1. Dec 31, 2017 at 11:01 AM
    18tundrasport
    18tundrasport [OP] New Member
    PA
    2018 tundra dc sport 4x4 super white
    Lund step bars, afe filter, Trd flow accelerator
    I seen this today when installing my nerf bars. On the driver side the e brake cable is rubbing the bed mount pretty hard so I put in some convoluted tubing to help protect it. Just an fyi, it may not be a big deal but figure I would share. Mine is a 2018 double cab.
  2. Dec 31, 2017 at 1:17 PM
    18tundrasport
    PA
    It felt a little wore I don't trust stuff like that so I took a measure of precaution.
  3. Dec 31, 2017 at 1:34 PM
    epa4wd
    epa4wd New Member
    Ed
    Will be installing side steps soon, will do this as a precaution. Thanks for posting.
    18tundrasport[OP] likes this.
  4. Dec 31, 2017 at 3:14 PM
    ZPMAN
    Minnesota
    If you live in the rust belt like me: I always put a dab of silicon on any nuts and bolts B4 assembly.
  5. Dec 31, 2017 at 7:00 PM
    Slayer
    Slayer Member
    Slayer
    thanks for the heads up brother.. :thumbsup:
    I'll have to take a look
  6. Jan 1, 2018 at 8:26 AM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    That split loom won't last, if it is rubbing, it'll rub right through it. As far as the brake cable goes, it is rubber outter layer, then flexible steel jacket, then inner liner, before you get to the cable, so it is pretty well protected. Your best bet would be to try and get one slack in the cable to get it off of the edge or maybe some of that heavy duty edge guard material to soften the edge.
    I'd recommend something like this, it has a metal inner structure that is incased in rubber. The rubber would help prevent rub through and the metal "backbone" means you don't have to worry about getting adhesive to stick and stay stuck on the frame rail.
    https://www.amazon.com/dp/B073TNRBS7/_encoding=UTF8?coliid=I81S8U9GNR5IA&colid=1Q5LXDATMSB6A&psc=0
    TXDrifter likes this.
  7. Jan 1, 2018 at 10:01 AM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    Cut the cable. No more rub
    Laz1388 and NewImprovedRon like this.
