Dust Cap Won't Fit New Hub
Discussion in '1st Gen Tundras (2000-2006)' started by carpenter356, Jan 5, 2021.
  1. Jan 5, 2021 at 12:33 PM
    carpenter356
    carpenter356 [OP] New Member
    Madison
    2006 DC Limited
    I have an issue with the new Durago front hub (from RockAuto) I installed this past weekend. The dust cap does not fit (too loose, just falls out...). I went with a new hub because I thought it would be nice to go all new components on my front-end rebuild, but now I am having regrets. I went aftermarket to save money, but now it's biting me. I bought two Durago hubs and I immediately checked the second one for fitment. They both have the same issue. I am definitely not installing the second Durago hub. This stinks because it took a lot of work to rebuild the knuckle myself and I can't undo this.
    The cap is not damaged in any way. It fits with good compression on the original hub. Do y'all have any suggestions on how to make it fit? and stay?
  2. Jan 5, 2021 at 8:12 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    How much are new dust caps that fit the hub?
  3. Jan 5, 2021 at 9:32 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    @carpenter356 exactly why I always try to buy OEM when it makes sense to. As @Stuck in the '00s noted it would be easiest to just get new caps that fit if they are reasonably priced as they should exist. This would save you the hassle of returning the additional hub if you are on the hook for return shipping/restocking fees. If you are feeling cheap maybe consider adding a bead of rtv silicone if the tolerances are reasonable and secure with a piece of tape to hold it in position while the silicone sets up.
  4. Jan 6, 2021 at 3:01 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I wouldn't worry about it honestly. It's really not going to hurt anything if it's missing.
    Smear some anti seize on the exposed threads and run it.
