Dual USB 4.2 Fast charger w/ pics
Discussion in '2.5 Gen Tundras (2014-2021)' started by 915tundra, Oct 24, 2019.
  1. Oct 24, 2019 at 2:39 PM
    915tundra
    915tundra [OP] New Member
    LEE
    WEST TX
    2017 Tundra TRD Pro
  2. Oct 24, 2019 at 2:40 PM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    Now my little boy can use his tablet while it charges, both slots are 2.1 fast charge...
    jeremyd and Hondoman like this.
  3. Oct 24, 2019 at 2:47 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Great job. I did this last year and its very helpful on road trips
    915tundra[OP] likes this.
  4. Oct 24, 2019 at 2:49 PM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    Thanks! Absolutely, can’t wait to put it to good use
  5. Oct 24, 2019 at 5:29 PM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Nice. I added 2 of these last year. One there and one up front.
  6. Oct 24, 2019 at 5:54 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
  7. Oct 24, 2019 at 5:57 PM
    senn4586
    senn4586 New Member
    Orange County
    2014 White Tundra
    Rear LED, inside LED
    Great job on this. I put mine in a while back and my girls are definitely glad I installed it.
  8. Oct 24, 2019 at 7:05 PM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    My only thing w those usb chargers is the bottom slot is upside down lol, then you have unfamiliar passengers trying to cram the usb in upside down ect, plus I also like having both slots where you insert the usb w the logo Side up , I’m very OCD lol
  9. Oct 24, 2019 at 7:08 PM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    Thanks brotha, I bet, w the tech age we live in the kids have a lot done stuff they can plug into the ports so it’s definitely a must imo lol
  10. Oct 25, 2019 at 7:04 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    That looks great (and SUCH an oversight on Toyota's part). How do you get access to that area to install one? Would love to do the same.
  11. Oct 25, 2019 at 7:20 AM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    That panel pops off, pull the panel towards the back of the truck. Then you just tap the wire harness w wire taps. Super easy!
    field8909 and bmann7 like this.
  12. Oct 25, 2019 at 7:22 AM
    bmann7
    WA
    See signature line
    Sounds easy enough - thank you! That'll certainly impress the kids too ;)
  13. Oct 25, 2019 at 7:38 AM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    No problem... Let me know if you run into any trouble, I’ll walk you through. You can order the outlets at powerwerks.com
    bmann7 likes this.
  14. Oct 25, 2019 at 7:42 AM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    Just a disclaimer here, you will have to slightly enlarge the diameter of the hole, using a step drill increase the bore to 1 1/8” and that’s will give you a nice tight, factory fit. the wire harness has a rubber protective sleeve, remove about 3-4” from the connector end and that will give you plenty of room for the taps. I should of took pics while I had it all apart, But I don’t mind popping off that panel to take any pics if needed. Also the nice thing if your OCD like me is the bezel is sold as a replacement part for $5 so if later you decide to go back to stock which I don’t see why anyone would but you can replace that little square, it screws to the back of the center console
  15. Oct 25, 2019 at 7:43 AM
    bmann7
    WA
    See signature line
    Awesome - any and all help appreciated, thank you.
