Dual battery setup
Discussion in '1st Gen Tundras (2000-2006)' started by lc69hunter, Sep 29, 2020.
  1. Sep 29, 2020 at 6:41 AM
    lc69hunter
    lc69hunter [OP] New Member
    Don
    2001 Black Tundra SR5
    gooseneck hitch, trailer brake
    I am getting ready to put an Iron Bull bumper and a winch on my 2001. I would like to run a dual battery setup like I have on my FJ40, but there is little room under the hood for a second battery.
    Any ideas?
  2. Sep 29, 2020 at 7:47 AM
    ajmorenoaz
    ajmorenoaz New Member
    2000 Tundra Sr5
    Why couldn’t you put it right inside the passenger side fender?
    bmf4069 and Pucks18 like this.
  3. Sep 29, 2020 at 8:31 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That's exactly where I would put one.
    Kongap likes this.
  4. Sep 29, 2020 at 11:08 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Didn't somebody actually put in a 2nd full size battery?
  5. Sep 29, 2020 at 11:33 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    That guy did in the picture I posted. For those on instagram he's Basil Lynch. He's got a sweet Tundra.
  6. Sep 29, 2020 at 12:35 PM
    Kongap
    Kongap New Member
    2004 SR5 DC
    Clean AF
  7. Sep 29, 2020 at 2:50 PM
    Professional Hand Model
    Hand Protectors
    Even the 2002 with ABS Module in the way there is some room in that general area for something.
  8. Sep 29, 2020 at 2:53 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    There’s a guy working on a mount with a builder I follow on fb
  9. Sep 29, 2020 at 3:58 PM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    Check out the Blue Sea ML-ACR if you go with a second battery. You can even jump yourself if your main goes dead.
    lamboboy732 and speedtre like this.
  10. Oct 1, 2020 at 11:32 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve been contemplating running a second battery under the truck on the frame rail so I can power things in the camper and eventually amps for the stereo too. No lost engine bay room and help balance out the lean a wee bit with a battery on the passenger side under the bed
    lamboboy732 and bmf4069 like this.
  11. Oct 2, 2020 at 7:14 AM
    chester
    chester best member
    2005 Double Cab SR5
    I had a 2011 Chevy Express van with a diesel in it. The second battery was mounted just like that. I wonder if you could buy the Chevy battery mount and use it on your Tundra.
  12. Oct 2, 2020 at 7:19 AM
    empty_lord
    05 rollover special
    There are companies that make trays for the sides of frames. Actually not to uncommon for hot rod classic trucks. It’s an idea for now. I may or may not do it.
  13. Oct 3, 2020 at 1:50 PM
    lamboboy732
    lamboboy732 New Member
    Haven't done the second battery on my tundra yet but we did my brother's passport/rodeo near the frame rail underneath. Really nice install because that truck had no engine bay room for another battery. I may do the same when I get around to my truck. I also second the blue sea isolator recommendation. It's a great solenoid and very convenient to be able to force connection when winching or to jump yourself.
  14. Oct 3, 2020 at 1:58 PM
    lamboboy732
    Photos for example of the setup we made for the passport/rodeo.
  15. Oct 3, 2020 at 2:20 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    SDHQ has a kit for a second battery in the engine compartment.
    I put a second full-size battery in the bed.
    Still working on finishing up some wiring.
  16. Oct 3, 2020 at 10:40 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
  17. Jan 2, 2021 at 11:43 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I'm back to thinking about a dual battery setup. I thought I read somewhere that if you moved/remounted the fuse box back towards the firewall a few inches, you could mount two batteries side by side, in the OEM battery spot. The batteries would be oriented 90 degrees to the OEM mounting. Anyone else recall anything like that? Too big of a PITA to move the fuse box to make it worth it?
  18. Jan 4, 2021 at 11:44 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    I am running a northstart group 31 up front. I am considering adding small group 24 starting battery to the right side. My thought right now is that it would be backup only. I just want to add a small charging circuit so it is always ready to party but other than that it just sets there looking pretty. If I need it hooking up jumper cables would be easy enough.
  19. Jan 4, 2021 at 2:16 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Unless I can mount two batteries side by side, I'm starting to lean towards the mounting of a tray, underneath, on the frame for the second battery. The spot towards the firewall, on the passenger side, it where a compressor will go. If I felt the need, I could set up remote terminals to make jumping myself easy.
