Dry Rot
Discussion in 'Wheels & Tires' started by chphilo, Sep 13, 2018.
  1. Sep 13, 2018 at 1:00 PM
    chphilo
    chphilo [OP] Tundra addict
    Western PA
    I just came back from PA state inspection. I was told that my tires are dry-rotting. This was unexpected since my tires have only 10k on them. I've had them for less than four years. The inspection guy told me that Nitto tires tend to do this. Is he right? Is this commonly what to expect for a truck that is always parked outside? (My garage is too small for my truck) All four tires look sort of like this. (the tires were manufactured only a few months before I purchased them)
    ColoradoTJ likes this.
  2. Sep 13, 2018 at 1:10 PM
    TOYOTAGUYS
    TOYOTAGUYS LOYALTOYOTA
    Alex
    Bellevue, WA
    ISO a Tundra
    Did you check the manufacturing date on them? They may only have less than 10k miles on them, but they could've been manufactured more then 3 years ago even though you've only had them for only
    3 years.
  3. Sep 13, 2018 at 1:10 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    my trail grapplers did this on my FJ after 4 or 5 years. i always did a 5 tire rotation so the spare wasn't always totally hanging out the back. we'll see how they hold up on the tundra.
    jewsNbrews likes this.
  4. Sep 13, 2018 at 1:13 PM
    chphilo
    Western PA
    I did check the date. They were a few months old when I bought them. (so about 4 years old)
    Would you guys say that it's time for me to get new tires or would it be safe to ride on them for a while?
  5. Sep 13, 2018 at 3:00 PM
    TOYOTAGUYS
    Alex
    Bellevue, WA
    ISO a Tundra
    It's probably time to buy new tires, but I'd try and contacting the manufacturer, and warranting them first considering they are only 4 years old and have 10k miles.
    Most tire brands have a 40-50k mile 5 year warranty.
    signalbobby and jewsNbrews like this.
  6. Sep 13, 2018 at 4:09 PM
    signalbobby
    signalbobby New Member
    Robert
    AZ
    16 Tundra PRO & 4R PRO
    time to do burnouts then rotate and repeat and rinse.
  7. Sep 13, 2018 at 4:14 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    :burnrubber::mudding:
    Time to drive it like you stole it for a week. After contacting them about a warranty and possible replacement.
  8. Sep 13, 2018 at 4:14 PM
    signalbobby
    Robert
    AZ
    very true.
  9. Sep 13, 2018 at 4:43 PM
    I would go to your local discount tire and use their dry rot/cracking meter. My factory craptastic BFGs were way worse than that and they would not warranty them.
    The suns UV rays really can take its toll on tires.
    4.5 year old ST tires, and this trailer sits outside. It used to have pretty good shade though. This year I will make wood covers for them.
    These are 6 years old. Always inside except on trips. 16201396-991C-447F-A335-7EF6C4DA6D78.jpg
    Tires are 2.5 years old, always inside.
    equin likes this.
  10. Sep 13, 2018 at 4:52 PM
    Professional Hand Model
    Hand Protectors
    Those trailer tires looking like spandex on cellulite
  11. Sep 15, 2018 at 1:23 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Is it just the tread on top or the sidewalls too? I’ve seen a lot of the tread do that on different tires, especially when they are out in the elements like that. Had a set of ko’s That did it and was told they were still fine. Only reason i replaces them was I later found a pretty good crack through a sidewall.
    Is your truck not a dd?
