Dropping mpg
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra5, Sep 3, 2023.
  1. Sep 3, 2023 at 11:39 AM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    About a month and half, my mpg went from 17.2 to 16.8.
    This week they replaced the alternator and fan clutch and for whatever reason reset the mpg meter.
    Now it’s only gotten up to 15.6 mpg. Is there a reason why mpgs are dropping?
  2. Sep 3, 2023 at 11:57 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Truck forgets everything when you reset the battery. It has to relearn how you’re driving, and the lifetime fuel economy meter was totally lost. I’m sure it also sat idling after the alternator was replaced. Idling is getting an mpg of 0.
    The only reason you would need to be concerned about anything is if your tank averages change significantly.
    Metro14536 likes this.
  3. Sep 3, 2023 at 12:05 PM
    1Tundra5
    Junior
    2015 White SR5
    do you think it will take about a week to get it back to what it really needs to read?
  4. Sep 3, 2023 at 4:11 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    15.5 is about all I get, if we're talking combined city/highway average.
  5. Sep 4, 2023 at 5:06 AM
    MountainMan
    MountainMan New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    I was getting 16.0 mpg up until a couple of weeks ago. Gas mileage dropped to 15 mpg. I thought I got bad gas.
    Then I remembered that every year in the fall in this region, they start using a "winter blend" gas that is more oxygenated in order to reduce emissions when there are air inversions.
    This results in 1-2 mpg less efficiency every year starting in late September.
    But, seems like it may have been introduced earlier this year.
  6. Sep 4, 2023 at 8:07 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I get 13.9 :burnrubber:
  7. Sep 4, 2023 at 8:40 AM
    seydou
    seydou Distinguished Member
    Why don't you hand calculate it? The truck estimate is notoriously inaccurate.
    Jaypown and Saltyhero13 like this.
  8. Sep 4, 2023 at 9:44 AM
    1Tundra5
    Junior
    2015 White SR5
    Oh wow
  9. Sep 4, 2023 at 3:37 PM
    Kyhokie
    Kyhokie New Member
    2017 toyota tundra SR5 4×4 inferno
    3" lift
    I feel like an idiot bc I only get 12.9
  10. Sep 6, 2023 at 6:33 AM
    stantontm
    stantontm New Member
    Tom
    2018 Cement Crewmax SR5
    Well, I work from home and I hardly ever hit the highway - I get somewhere around 12 +/- 0.5
  11. Sep 6, 2023 at 7:12 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I stand corrected..
    PomDad likes this.
  12. Sep 6, 2023 at 10:01 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    You guys are doing it wrong. My MPG went up after I disconnected the battery, reset mine and jumped on the highway immediately after.
    But really, I wouldn’t worry about it. The reset is likely the cause and that MPG is not abnormal for the Tundra. Our Sequoia is around 13.8.
  13. Sep 6, 2023 at 10:17 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    ^^^This. Same thing with "Range" estimates. Mostly useless.
  14. Sep 6, 2023 at 10:21 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    It's great to get a ballpark figure. Remember, it is often labeled as a "cruising" range. That means going on the highway at certain speed. If you drive around town half the tank, of course it will be inaccurate.
  15. Sep 6, 2023 at 9:45 PM
    MountainMan
    2021 1794 Edition
    My MPG monitor is very accurate. When I fill the tank, I can get the gas level to the exact same spot in the filler neck every time. I was amazed how accurate it was; down to the tenth of a gallon.
