Dropped bolt/screw
Discussion in '1st Gen Tundras (2000-2006)' started by Thinckley0505, Aug 27, 2024.
  1. Aug 27, 2024 at 2:36 AM
    Thinckley0505
    Thinckley0505 [OP] New Member
    2006 SR5 DC V8 4WD
    Stick
    I was replacing the head unit in my 2006 DC, and dropped one of the mounting screws in the center console, I’m not sure where it dropped and I couldn’t see it. What should I do?
  2. Aug 27, 2024 at 2:41 AM
    Thinckley0505
    2006 SR5 DC V8 4WD
    Stick
    Another question is it a serious problem or is it just a possible rattling annoyance?
  3. Aug 27, 2024 at 4:21 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Most likely possible rattle. Slight chance it could lodge in the HVAC controls. Use a telescoping mirror and magnet and you may find it. If not drive on.
  4. Aug 27, 2024 at 5:38 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    It might rattle depending on where it fell, or it might not... If your radio is secure and not loose, then I wouldn't worry about it. If it has a little play then take one of your other screws to the hardware store and find another screw that will work.
    I had a front wheel drive car years ago (with a V6), and you had to undo the motor mounts and rock the engine forward to change spark plugs. I managed to drop a spark plug down behind the engine, and I couldn't find it anywhere. Ended up buying a replacement plug and moving on... Years later, when doing some other work, I found the spark plug. Somehow it stayed put for several years, and it never made a noise or rattled. Point being, your lost screw may never bother you.
    Just think about how many 10mm sockets have been lost in similar situations
  5. Aug 27, 2024 at 6:00 AM
    Retired...finally
    My concern would be the MIA screw fouling a moving mechanism if there are any. If you see other objects like coins, french fries, paperclips or 10mm sockets, button it up and drive it.
  6. Aug 27, 2024 at 6:35 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Happen to me, I have lost 2 10mm bolts back there. Check the hvac gear right under it and keep it pushing
  7. Aug 27, 2024 at 6:41 AM
    shifty` In South Dakota Trouble ain't hard to find
    And hope it doesn't get caught in a gear. Because if it does, the plastic gear will break before that bolt does...
  8. Aug 27, 2024 at 6:54 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Yeah, had had a an auxiliary cord from the radio I didn’t zip tie hanging down and almost busted a gear
    shifty`[QUOTED] likes this.
  9. Aug 27, 2024 at 7:37 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Take it for a spin down a dirt road. See if it falls out the bottom. That’s what happened to me in my last truck. Rolled right out a week later.
    Jack McCarthy likes this.
