Driving Lights to replace my OEM fog lights
Discussion in 'Lighting' started by mbrueche, Feb 14, 2016.
  1. Feb 14, 2016 at 11:35 AM
    mbrueche
    mbrueche [OP] New Member
    2015 Tundra Limited
    I'm looking for driving lights that will fit in the current fog light location of my 2015 Tundra Crewmax. Any ideas?
  2. Feb 14, 2016 at 12:25 PM
    Cutter29
    Cutter29 ...
    Utah
    2015 Super White TRD PRO
    Rigid makes a mounting bracket for that location. You can choose from the cubes they offer. Lots of different patterns. They have a DOT legal option. Retrofit source also has an even easier plug and play Toyota fog. Believe it is LED and I've read it is equal to the rigid DOT option in output. I haven't done much research yet but I plan to swap my fogs for one of the two after headlight retrofit is complete.
    MotoTundra likes this.
  3. Feb 14, 2016 at 12:48 PM
    mbrueche
    2015 Tundra Limited
    Thanks!
  4. Feb 14, 2016 at 2:24 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    I replaced my fogs with Diode Dynamics lights. Plug and play. I rewired them to come on with my high beams. Probably the best and most useful mod I've done.
  5. Feb 14, 2016 at 2:34 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Rigid D2 H/L with fog mounts. You can wire the low side to your existing fog light circuit and the bright side to your hi-beams. No need to install any extra switches nor run wires into the cab.
  6. Feb 14, 2016 at 8:05 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Thats a great idea....
  7. Feb 15, 2016 at 1:28 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
