Driving in Manual Mode
Discussion in '3rd Gen Tundras (2022+)' started by 2494, Apr 20, 2024.
  1. Apr 20, 2024 at 5:23 AM
    2494 [OP] New Member
    2024 Tundra 1794
    2024 with 1,000 miles. Any feedback on long term wear and tear on tranny? Drove in manual mode yesterday and really enjoyed the performance
  2. Apr 20, 2024 at 6:56 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    You're only doing manually what the transmission would do automatically. No difference to the gears.
    2494[QUOTED][OP] likes this.
  3. Apr 20, 2024 at 7:16 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I use this mode all the time, especially when towing and starting up at a light or stop sign. Otherwise, the transmission wants to be in 3rd and it seems to take forever to get moving with lots of engine spinning!
    I pull it down into 1st and it takes off much better. Just need to make sure to shift up quickly.
    2494[OP] and Mattedfred like this.
  4. Apr 20, 2024 at 7:20 AM
    It's not an actual manual mode. It's a gear limiter. It won't go into a gear higher than what you selected, but it operates normally otherwise. From a stop put it in S4 and drive without touching the shifter. It'll shift through the gears normally up to 4th, and won't go to a higher gear than that. It's mostly useful for engine braking down hill/towing/etc.
    As for wear and tear, that will depend on if you are revving it out to long before bumping the gear limit up. How you drive it will determine the wear. Using S-mode will not hurt the truck unless you are doing something goofy in the way you drive it.
