Driving around with knock sensor fault code
Discussion in '1st Gen Tundras (2000-2006)' started by dpr64, Jul 11, 2020.
  1. Jul 11, 2020 at 11:33 AM
    dpr64
    dpr64 [OP] New Member
    2003 AC 4x4
    Picking up my father's 2002 Tundra with the 4.7 next week to take over and found out he has been driving it around for 2 years with the knock sensor faulty code/check engine light... Will there be any damage as a result? I do not want to walk into an issue.... Plan on replacing it as soon as I pick it up.
    Thanks!
  2. Jul 11, 2020 at 12:15 PM
    Professional Hand Model
    Hand Protectors
    Sweet Deal on the hand me down 1st Gen.
    Will there be damage? Hard to tell.
    Here is how I look at Sensors: They are there for a reason so you should replace them. There are two. They are near the Starter. All three of these items are under the Manifold and take some work getting to them. I suggest replacing all 3 items at the same time.
    The Knock Sensors cost about $170 each from the Stealership and you can buy a Reman’d Starter (Heavy Duty Version 2.0kV) for about $130 from Denso Online.
    Assuming your truck is 4.7L.
  3. Jul 11, 2020 at 12:17 PM
    dpr64
    2003 AC 4x4
    Yes, 4.7...
  4. Jul 11, 2020 at 12:22 PM
    Hand Protectors
    Getter dun!
  5. Jul 13, 2020 at 4:18 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I drove around for quite a while with mine on. No harm in it;just shitty mileage. Take a look between the intake runners at the engine valley and see if you can see the wires or if theres a rat's nest in there.
