Driveshaft DIY vs Shop
Discussion in '1st Gen Tundras (2000-2006)' started by ctxstepside, Apr 14, 2025.
  1. Apr 14, 2025 at 8:02 AM
    ctxstepside
    ctxstepside [OP] New Member
    Soo I’m about to order a new u-joint and carrier bearing and I wanted to ask yall if you feel it’s worth it to DIY a driveshaft rebuild or to just take it to a shop? I’m fairly mechanically inclined and confident in my skills, but I have heard rebuilding these shafts can be a major pain so I wanted to see what you guys think! If it helps I don’t think I have a double cardan.
  2. Apr 14, 2025 at 8:23 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    I personally would take mine to a driveline specialty shop. I too do all my own maintenance and am confident, but this is one where I'll leave it to the pros. Any balance issues could potentially ruin a lot of things. Diffs, Tcase, etc. If it were only the carrier bearing, I would do that. But a full rebuild, nah.
  3. Apr 14, 2025 at 9:43 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I had mine professionally done, new u-joints and career bearing. I supplied them with all the parts. I dropped off the truck and picked it up 2 hrs later. The told me my drive shaft was out off balance. The truck drives even better after that.
    I paid $150 in parts and $225 for the labor. They said $75 of it was the remove and install of the driveshaft.
    there’s an option of just dropping off the driveshaft also
  4. Apr 14, 2025 at 10:18 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Agree with other posters. While it is not very hard to change u-joints and CSB on our drive shafts, for the price of a shop doing it you also get a balance and the peace of mind of such a critical part being repaired correctly.
    That being said, I've removed driveshafts myself and brought them to shops for repair in the past. I haven't ever brought my whole vehicle there for them to do the work.
  5. Apr 14, 2025 at 12:04 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Agreed. As long as you mark the flanges on the each end so that install orientation is the same as when it came out.
  6. Apr 14, 2025 at 4:06 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I did just the u-joints and it wasn't bad at all. Took less time than it would to drive to the shop. (I may have gotten lucky though)
  7. Apr 15, 2025 at 6:51 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    Personally I would do it myself, and then if there were any vibration issues I'd pull it and take it to a shop for balancing if needed.
  8. Apr 15, 2025 at 1:51 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I think it depends on if you have time and how valuable your time is. I’d bring the shaft in and drop it off. But I also just bought a shaft off a wreck with new CB. If u-joints need to be done I’m gonna drop it off and have them replaced and balanced. If not, I’m just gonna pop it on.
