Driverside rear lean
Discussion in '1st Gen Tundras (2000-2006)' started by Godsota1708, Aug 24, 2021.
  1. Aug 24, 2021 at 4:35 AM
    Godsota1708
    Godsota1708 [OP] New Member
    David
    Baltimore,MD
    2000 Tundra V8 Limited
    K&N intake JBA headers Performance cats Gibson catback exhaust Pro-comp uca's Bilstein front Bilstein b110's rear moog strut mounts Moog lower ball joints New cv joints New tie rods 1" strut spacers front 2" blocks rear Icon 1.5" add- a- leafs New rack & pinion New rack & pinion bushings Sway bar Sway bar bushings Redline wheels Dick cepek fun county 285/75/R16
    I have just recently got work done on my suspension. I had Bilstein put in the front and Bilstein put in the rear. Icon one and a half inch add-a- leafs put in the rear and 2 in blocks put in the rear. The truck has been lifted but the problem is the driver side rear is an inch lower than the passenger side rear. Could anyone give me some advice as to why this might be happening? Thank you.
  2. Aug 24, 2021 at 5:37 AM
    DSLKSL
    DSLKSL New Member
    Don
    Do you have a full tank of gas?
  3. Aug 24, 2021 at 6:13 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    From what I have experienced - when adding new shocks set at same height the truck will lean towards drivers side. I assume and have had knowledge transferred related to how geometry factors in between the front and rear (springs). Did you add a spacer/ shim to drivers side? Is the truck level in the front? This is a 3rd gen spot to ref.
    https://www.tundras.com/threads/3rd...ight-measurement-request-hub-to-fender.19016/
  4. Aug 24, 2021 at 6:34 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Did you double check that they put everything in? Both sides have the same number of leafs?
  5. Aug 24, 2021 at 7:08 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    First, measure the center of the hub to the bottom off wheel well/fender flare. That will give you an exact measurement of how much lean there is.
    9/10, it’s usually the drivers front that has lean. Curious to why you went with add a leaf and a block?
    Siebler likes this.
