Drivers side heat issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Bwilliams_7, Oct 13, 2023.
  1. Oct 13, 2023 at 9:45 AM
    Bwilliams_7
    Bwilliams_7 [OP] New Member
    2009 Tundra I’ve noticed as it’s getting colder outside that when I kick the heat on I’m getting lukewarm heat at best on drivers side but full heat on the passenger side.
    Air flow is also much lower than that on the passenger side.
    When A/C is running I have full air flow and cold air on both sides.
    The truck does make an odd noise typically when it’s first started (something under the dash).
    I’ve reviewed quite a few posts with somewhat similar problems but responses are kinda all over the place.
    Seems like a blend door issue but just wanted to get some opinions and see if anyone else has had this issue.
    Thanks in advance!
    08TundraG likes this.
