Driver's Side Door Bracket Crack
Discussion in '2nd Gen Builds (2007-2013)' started by 10TundraSR5, Aug 8, 2019.
  1. Aug 8, 2019 at 12:45 PM
    10TundraSR5
    10TundraSR5 [OP] Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    I just saw this today getting out of my truck after lunch. Anyone else had this happen? It's not cracked all the way through. Just on top. You can see the crack right about the hole and above the 'F' and 'L'. Door still operates like normal.
  2. Aug 8, 2019 at 12:52 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I wonder if the wind ever hit the door and forced it open real hard?
  3. Aug 8, 2019 at 1:05 PM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
    Isn't that the plastic door check?
  4. Aug 8, 2019 at 1:41 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    This is the plastic door check. Very easy to replace and cost about 90 dollars for gen 2/3. I just ordered one as the wind grabbed my door one day and slammed it open. Ever since then the door check has been so creaky!
  5. Aug 9, 2019 at 4:08 AM
    10TundraSR5
    Tennessee
    THIS! Thank you all for the reply! I've noticed the door is creaky versus the passenger side door. Do you happen to have the part number handy?
    Tundyfundy[QUOTED] likes this.
  6. Aug 9, 2019 at 4:19 AM
    What year is your truck? I'll look on Sparks for it.
    Tundyfundy likes this.
  7. Aug 9, 2019 at 4:27 AM
    Here you go. Based on your member name, I searched a 2010 SR5 with the 5.7. Most likely the part number is the same on all of the 2nd Gen years. The second #19 is the drivers door. https://www.sparksparts.com/auto-pa...v8-gas-engine/body-cat/lock-and-hardware-scat
  8. Aug 9, 2019 at 4:30 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  9. Aug 9, 2019 at 4:35 AM
  10. Aug 9, 2019 at 5:27 AM
    bvia
    bvia New Member
    None
    My driver side door check is cracked also, but at >$50.00, I just live with the popping and clicking...
    B
  11. Aug 9, 2019 at 5:34 AM
    Rex Kramer
    Georgia
    I knew the drivers side check was busted when I purchased my '07, but I failed to note the passenger side. My first passenger was my 81 year old mom, and when I dropped her off at her house she hung on to the door as she opened it. The long heavy regular cab door snatched her right out of the truck onto the lawn... she tucked & rolled, good times.
  12. Aug 9, 2019 at 6:11 AM
    10TundraSR5
    Tennessee
    Thank you!!!!!
  13. Aug 9, 2019 at 10:29 AM
    10TundraSR5
    Tennessee
    For what's its worth, I looked at it again and I believe just the plastic coating on top cracked. The metal piece is still holding strong.
    TheBeast likes this.
  14. Aug 9, 2019 at 11:37 PM
    Tundyfundy
    Bay Area, CA
    Mainly you should on ly be concerned if its structural or makikng noise. Mine is popping and when I put the sound deadening in the doors it made them heavier and the sound got louder. If it was another door I might not care but its the driver door so I figure every time I use the truck Ill hear it.
