Drivers side clunk
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dustydirt19, Apr 3, 2018.
  1. Apr 3, 2018 at 4:14 PM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    I have a procomp stage 2 lift on my 15 tundra. I noticed lately when I hit a pothole or a bigger bump I can hear a clunk in the front left of my truck. Its almost as if i can feel it under my feet when at the pedals. Anyone else have this problem or know what it could be?
  2. Apr 3, 2018 at 4:29 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Haha I know it's been awhile
    Y0TA PR0 and GNTundra like this.
  3. Apr 3, 2018 at 4:31 PM
    Dustydirt19
    Dustin
    Duluth, MN
    I know some people say this but they were getting this when turning. Mine only happens when I hit a bump at slower speeds. Nothing ripped or leaking
    GNTundra likes this.
  4. Apr 3, 2018 at 4:36 PM
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    "clunk" is usual one heavy object hitting another, I would put the truck on a lift and see if there is a lot of slack in the front left tire when moving it around and check all the bushing to make sure they good.
  5. Apr 3, 2018 at 5:56 PM
    Dustydirt19
    Dustin
    Duluth, MN
    I did it myself
  6. Apr 3, 2018 at 5:56 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Grease everytime I get an oil change. Living in Wisconsin now at the new pad
  7. Apr 3, 2018 at 5:59 PM
    Check all components associated with the lift, knuckles, upper lower UCAs, crossmembers, IDK hope it gets resolved
    Dustydirt19[OP] likes this.
  8. Apr 3, 2018 at 6:39 PM
    Dustydirt19
    Dustin
    Duluth, MN
    It's not a super loud clunk either and only happens on larger bumps dips and potholes
  9. Apr 3, 2018 at 6:50 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sway bar?
  10. Apr 3, 2018 at 7:03 PM
    TheBeast The Beach
    sway bar, engine skid plate, LCA..check everything is tight.
    831Tun and Dustydirt19[OP] like this.
  11. Apr 3, 2018 at 7:08 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Can all this be checked on the ground or should it be up in the air?
  12. Apr 3, 2018 at 7:15 PM
    Can also be UCA
  13. Apr 3, 2018 at 7:53 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Had one too. Procomp blows. Traded it away.
  14. Apr 4, 2018 at 7:24 AM
    Thee_Oddball
    Eric
    Chicago
    I think I know what the problem is, was there a recent "protest" that blocked the highway while you were on your may to work?..... I think I know what the noise is:rofl::rofl:
    Dustydirt19[OP] and TXMiamiFan like this.
  15. Apr 4, 2018 at 8:57 AM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Loose nerf bar/running board?
