Driver's side clunk, driving forward after starting truck
Discussion in '2.5 Gen Tundras (2014-2021)' started by FWC, Feb 20, 2020.
  1. Feb 20, 2020 at 3:12 PM
    FWC
    FWC [OP] New Member
    Upstate NY
    2019 Tundra Black Platinum
    So I have a 19 Platinum 4x4 with 2700 miles on it. When I first start up and drive off there is clunk coming from the drivers side front wheel area. Cold or warm doesn't matter, but only happens when I am driving forward after I start it up. If I have been driving and put it in park and then to drive and move forward it doesn't happen. I took it to the dealer today and they drove it, heard it and said it is normal, the tech thought it was wheel engaging the spline in the shaft as it moves forward. Anyone else have this issue? Doesn't sound right to me.
  2. Feb 20, 2020 at 3:34 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    It's probably the ABS self test. My SR5 did it, and so does my Pro.
  3. Feb 20, 2020 at 3:43 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The tech probably should've told you what @19TurdPro did.
    NewImprovedRon and FWC[OP] like this.
  4. Feb 20, 2020 at 3:48 PM
    FWC
    FWC [OP] New Member
    Upstate NY
    Thanks guys, as long as it is normal.
  5. Feb 20, 2020 at 4:45 PM
    dspilot
    dspilot Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    Hmmm....my 2019 SR5 4x4 does the same thing. Glad to hear that this is something normal. I mostly notice it after I back out of the driveway as soon as I start going forward.
    Fish Wagon and Supra_man like this.
  6. Feb 20, 2020 at 4:49 PM
    FWC
    FWC [OP] New Member
    Upstate NY
    ^^^ same here
    dspilot likes this.
  7. Feb 20, 2020 at 5:05 PM
    NOLA Tundra
    NOLA Tundra Sandbagging
    Jesse
    2019 Quicksand CM
    3” level leds all around Morimoto headlight and fog light bulbs Flowmaster American Thunder
    Yep we all have it nothing to worry about. I was freaking out to when I had my first Tundra because I thought it had something to do with the level kit I installed because I didn’t notice it before that, but just lived with it because I figured dealership would tell me it was my fault. Traded that one in and fresh off the lot my new truck did it and best way the dealership could describe is” they all do it something with the breaks”
    FWC[OP] and dspilot like this.
  8. Feb 20, 2020 at 5:20 PM
    19TurdPro
    2019 Tundra TRD Pro
    It is. You can play with it if you want. It happens at like 6MPH, so you can creep at 2 for a while, then when you hit 6, *clunk*
  9. Feb 20, 2020 at 7:39 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    ABS LOL, technically speaking, we all drive a clunker.
  10. Feb 20, 2020 at 7:54 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Same here!
  11. Feb 20, 2020 at 7:59 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Completely normal. If you search you'll see many threads on it, at least once a month there's a new one.
  12. Feb 21, 2020 at 8:42 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    I've noticed the same thing, glad to hear it's something so simple!
    FWC[OP] likes this.
  13. Mar 2, 2020 at 3:49 AM
    blanchard7684
    blanchard7684 New Member
    Just picked up a 2019 PRO and heard this about 4 times in 150 miles.
    I crawled under the truck with grease guns in hand absolutely certain it was the carrier or splines on drive shaft needing greasing.
    lol...no grease points on drive shaft.
    This thread was a timely help.
    FWC[OP] likes this.
  14. Mar 2, 2020 at 3:55 AM
    Cthulhu
    My truck doesn’t do this, everyone of y’all is bat-shit crazy, or your negasonic converters are fugged.
    jclem65 and dspilot like this.
  15. Mar 2, 2020 at 7:44 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    It’s the ABS slipping one in the chamber.
  16. Mar 2, 2020 at 8:08 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Any chance your door locks were set to auto lock when you start driving for the first 11 years? If so, you would have heard the door locks over the sound of the ABS pump, same time, same speed.
    My ‘08 Tundra does it, my ‘06 Tacoma did it...
    1lowlife and deptrai[QUOTED] like this.
  17. Jan 12, 2021 at 10:05 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I have this on my truck also, less than 1000 miles. Scared the sh*t out of me at first. It's a normal test and is stated in the manual as such. However, since I am a paranoid ass that has worked as a quality engineer for far too long, I wont be fully at ease until I test it myself. Planning to disable my abs for a few days to see if it goes away consistantly.
  18. Jan 12, 2021 at 10:13 PM
    19TurdPro
    2019 Tundra TRD Pro
    You don't have to go that far. It kicks in at about 6 MPH while going forward. Hammer it in reverse, keep it under 6 while going forward. You can go for miles without it as long as you keep it under 6. Once you hit 6, clunk.
  19. Jan 12, 2021 at 10:14 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    :facepalm:
  20. Jan 12, 2021 at 11:06 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Haha...its just so weird though, never heard of anything like this before.
  21. Jan 13, 2021 at 2:46 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    To be fair, the manual doesn't really give any details on when to expect to hear it from what I recall.
  22. Jan 13, 2021 at 5:38 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Nor does the dealer when you bring it in, telling them there is a noise in the front end when taking off. DOPES !
  23. Jan 13, 2021 at 6:18 AM
    Kanobi13
    Kanobi13 New Member
    Not normal truck is going to fly away at any moment!!!
  24. Jan 13, 2021 at 8:44 AM
    Hojoredsport
    Hojoredsport New Member
    Howard
    2019 red trd sport
    Leveling kit rims and tires bull bar cat back system
    My 2019 trd sport does it.dealer said it was the breaks no t to worry.
  25. Jan 14, 2021 at 8:32 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    My 2019 has it. I don't like it either its the ABS checking the breaks.
  26. Apr 3, 2022 at 4:23 AM
    Szach21
    Szach21 New Member
    Shaun
    Gray 2019 SR5 TRD
    Thank god ! So glad I found this. Just sold my 08' SR5 TRD w/ 230K mi which did NOT do this at all. Picked up the same truck but a 19' w/ 77K mi and this noise has been freaking me out ! Such an odd "engagement" type sound.
  27. Apr 4, 2022 at 11:22 AM
    EdmondSchulze
    EdmondSchulze New Member
    Edmond
    2021 Army green Toyota tundra
    Cold air intake, programmer,throttle enhancer,dual exhaust, throttle body spacer,battery stabilizer. Looking for performance coil packs.
    I have a 2021 trd off road and it makes the clunking noise.
  28. Apr 4, 2022 at 7:23 PM
    Sc00ter
    Sc00ter New Member
    AZ
    Does it kinda sound like farting in a bathtub? I've noticed a weird sound when pulling out of a parking spot and straightening my wheel. I thought it was rubbing at first but I looked around the wheel wells and didn't see any signs and noticed the sound wasn't always at the same point of straightening the wheel, and it only happens after start up. I've kinda just be yolo-ing it until I saw this thread
    FlyingWolfe likes this.
  29. Apr 4, 2022 at 8:42 PM
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    You described it to a tee I don't know if this is what everyone is talking about. But mine does this. Drives me nuts cause I don't know what it is. But maybe this is what everyone is describing.
    Fish Wagon likes this.
  30. Apr 4, 2022 at 10:52 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
