Drivers Seatbelt Light Flashing
Discussion in '1st Gen Tundras (2000-2006)' started by smokey0810, Aug 6, 2021.
  1. Aug 6, 2021 at 9:24 PM
    smokey0810
    smokey0810 [OP] New Member
    '03 Tundra SR5 AC 4WD
    Got in my truck tonight after work. Buckled up, and the seatbelt light was flashing intermittently on the ride home. Any thoughts?
  2. Aug 6, 2021 at 9:28 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Bad connection in the latch.
  3. Aug 6, 2021 at 10:47 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Make sure your underseat electrical connections are all tight...
  4. Aug 7, 2021 at 9:09 AM
    smokey0810
    Just thankful it wasn't a warning for an upcoming accident on the ride home...lol....
  5. Aug 7, 2021 at 9:29 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Exactly what I was going to ask. If I leave something of substance in my passenger seat it will trigger the sensor/light.
    1lowlife, des2mtn and NewImprovedRon like this.
  6. Aug 7, 2021 at 11:52 AM
    smokey0810
    Nope. Only weight was my rear end heading home from work.
  7. Aug 7, 2021 at 12:20 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I bought a brand new car when I graduated from High School. A nice Plymouth Satellite. When I left the dealer, the seat belt buzzer would go off and on a couple of times every block. I kept fiddling with it but nothing worked. I was getting ticked off, so I decided to go back to the dealer and make them fix it. Being more than a bit angry, I hit the brake and the clutch getting ready to make a u-turn to go back. My trade in was a standard, this was an automatic. I stopped very abruptly giving the seat belt a good hard yank. The buzzer stopped buzzing at that point and never acted up again. I'd suspect a bit of crud in the belt connector, or maybe a bit of corrosion on the contacts. Blow it out with compressed air at the highest pressure available and see what happens. Contact cleaner might help, but be sure to use one that's plastic safe and dries completely. You don't want something that leaves oil behind and attracts dirt and dust.
    smokey0810[OP] likes this.
  8. Aug 8, 2021 at 4:28 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    I dislike the seatbelt warning light and just removed the light when I was in replacing burnt out bulbs.
    hammeron likes this.
  9. Aug 9, 2021 at 11:25 AM
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    Dang I wish I would have thought to do that when I replaced the burnt out D bulb recently:(
  10. Aug 10, 2021 at 8:12 AM
    Premiumjams
    Premiumjams New Member
    Tundra 2003 rear suicide doors
    I had the same issue on the 2003 Tundra I bought this year. The seatbelt would flash intermittently. Irritating. And distracted my driving which it can be dangerous to take your eyes off the road even less that second sometimes. Whenever I grabbed where the seatbelt snaps in and wiggle & hold it in place the light would stay off. After I let go and moved around in my seat a bit it would soon return, that told me to replace the snap in assembly. You have to unclip the cable under the seat and unbolt the 4 bolts and remove the seat from the cab to unbolt the assembly with the one bolt that attached it to the side of the seat, bolt a new one in and reinstall the seat and electronic cable. Easy do it yourself job for under $50. The new one no longer has that wiggle to it and the light has never come on again.
    hammeron and NewImprovedRon like this.
  11. Mar 1, 2025 at 9:01 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    straight up. i don't have to take my dash apart so maybe i'll just stick some electrical tape over it.
  12. Mar 2, 2025 at 5:54 AM
    Or you could just fix the problem. There’s plenty of info on this forum explaining how to do so.
  13. Mar 2, 2025 at 10:02 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    thank you so much for your input. back to your basement
  14. Mar 2, 2025 at 11:02 AM
    I reply with constructive feedback; you reply with insult. I see you are a the highest quality of person. Carry on!
  15. Mar 2, 2025 at 11:19 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    ok buddy, thanks for the unsolicited advice
