Drivers seat stuck all the way forward!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shattmortland, Aug 14, 2023.
  1. Aug 14, 2023 at 7:58 PM
    Shattmortland
    Shattmortland [OP] New Member
    2019 tundy
    Help!
    It all started when my recline on the drivers seat stopped working. I jiggled the switch enough to be sitting in the full erect position for a few days. Then I got into the seat switches 2 weekends ago, busted out the circuit board and fried the fuse (heard it pop, literally cannot find it in the fuse box in the cab), and now my seat is stuck full boner and all the way forward. Verryyyyy fun to drive around now. Does anyone know what fuse and where it is to replace so that I can at least slide it back and then replace the circuit board (which I think is the problem)? Fuse cover explicitly says "driver power seat" or similar for 2018 and earlier. But not 2019.....
  2. Aug 14, 2023 at 8:11 PM
    2mchfun
    Welcome from OKC! Sometimes fuses share circuits, so labels aren't always 100%. Why not just pull fuses one at a time and check them out or even swap around same amperage rating fuses until you get it figured out? Owners manual always has fuse diagram. Wiring diagrams can be found by clicking on forums, scroll to garage heading and electrical sub heading, click that and wire diagrams are there.
  3. Aug 14, 2023 at 11:53 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Should be on the interior fuse panel which will consist of 2 rows of fuses; you'll be looking for a 30amp fuse on the left side of that panel...
    3rd fuse down from the top (left hand side) should be 30amp for the front passenger seat (labeled as FR P/SEAT RH)
    2nd fuse from the bottom (also on the left side) should be another 30amp fuse and this one should be for your driver's side front seat (labeled as FR P/SEAT LH)
    If for some reason your fuses have a different orientation, just search for 30amp fuses and look for the one that's popped...
  4. Aug 15, 2023 at 4:29 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I hate it when that happens!
  5. Aug 22, 2023 at 4:16 AM
    Shattmortland
    2019 tundy
    Found it! It's the 30 amp relay that is rearmost in a group of 4, that are above those 2 rows of fuses, oriented perpendicular to them (facing the passenger seat).
    Replaced it and viola! Everything works including the lay back!
    lerbud1 and 2mchfun like this.
