Drivers seat is loosing support after 17 years...
Discussion in '1st Gen Tundras (2000-2006)' started by Alltimehigh, Oct 20, 2021.
  1. Oct 20, 2021 at 9:18 AM
    Alltimehigh
    Alltimehigh [OP] New Member
    Can I just swap it with the passenger side seat or will there be problems?
  2. Oct 20, 2021 at 11:07 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    How would you change over the arm rests and get to the controls on the side of the seat if the console is in the way?
  3. Oct 20, 2021 at 11:35 AM
    Alltimehigh
    The armrests look identical on both seats but the tilt control would be an issue I guess. Probly not gonna work.
  4. Oct 20, 2021 at 11:40 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    There's a thread somewhere about loosening/retorquing track bolts or replacing the track
  5. Oct 20, 2021 at 11:42 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Jack McCarthy and alb1k like this.
  6. Oct 20, 2021 at 2:16 PM
    Alltimehigh
    Yes its just the foam. Those links are great thanks.
  7. Oct 21, 2021 at 5:40 AM
    TundraMidwesterner
    Northern Illinois
  8. Oct 21, 2021 at 7:00 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
  9. Oct 21, 2021 at 9:39 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    had that happen on my 06 4runner, took it to a local upholstery shop that does good work on some nice cars. Fixed it right up, $500 to rebuild the driver seat foam and all.
    BravoDeltaRomeo likes this.
