Drivers door popping '15 Tundra CM
Discussion in '2.5 Gen Tundras (2014-2021)' started by rt_tundra_co, Dec 5, 2018.
  1. Dec 5, 2018 at 3:25 PM
    rt_tundra_co
    rt_tundra_co [OP] I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    I'm going to try and attach a video I snagged with my phone.
    When opening and closing the drivers door there is a popping sound on the part that holds the door in a few detects. The hinges are good, not bent and the door operates perfectly otherwise. The part in question moves a little but when it makes the popping noise. I'll guess at 2 pops per full door opening and closing.
    Anyone have experience with this type of issue? Thanks!
    Erichudgins likes this.
  2. Dec 5, 2018 at 4:00 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    mine does the exact same thing lol. its that little black piece between the hinges... mine is cracked.. how I don't know but It is lol. but it pops every single time I open my door. I just haven't had time to fix it. looks like the door panel will have to come off but an otherwise easy fix.
  3. Dec 5, 2018 at 4:52 PM
    mcchase
    mcchase New Member
    chase
    You can try and tighten the bolts that attaches the door check to the door. They are known to loosen and cause the popping. Just don’t tighten them too much or you’ll shear the bolt. Don’t ask me how I know...
    Black Wolf and Erichudgins like this.
  4. Dec 5, 2018 at 5:23 PM
    Yoda1
    Yoda1 New Member
    2016 MGM Tundra Crewmax
    My 2016 does the same thing. So annoying.
  5. Dec 5, 2018 at 5:25 PM
    This^^^ too..
  6. Dec 5, 2018 at 6:33 PM
    rt_tundra_co
    '15 SR5 CM TRD
    Bolts were tight when I looked at them. Tried to loosen and then re-tighten.Unfortunately no success...
  7. Dec 5, 2018 at 6:42 PM
    rt_tundra_co
    '15 SR5 CM TRD
    This video looks like it does a very good job of showing how to replace the door check stopper on a rear door of a Tundra: https://www.youtube.com/watch?v=gFOS7PCJDUs. It's a $20 part that will take about an hour to change.
  8. Jan 28, 2023 at 8:44 AM
    Stoogefan
    Stoogefan New Member
    2015 Tundra Limited
    Thanks for all of the info. I replaced with the dormant part for $11 on Amazon. No mods required and completed in 15 mins. Here is a picture of the part. Shaft etc the same size so not cutting
    batman900 and Leo's first like this.
