Drivers Door Lock with Key
Discussion in '2.5 Gen Tundras (2014-2021)' started by BRICK916, Aug 1, 2022.
  1. Aug 1, 2022 at 8:32 PM
    BRICK916
    BRICK916 [OP] New Member
    C
    2018 tundra Platinum
    3 inch litt
    Ok maybe I am dumb. I stick the key in the driver's door and turn left or right. Door will not unlock or lock. Any ideas. Been like that since day 1. Key for works just fine. What am I missing??
  2. Aug 2, 2022 at 3:01 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    The key only works one way. Despite it fitting in both ways. If you look at the cut it’s different on one side vs the other. I use mine regularly to lock truck with it running while dogs inside with ac on. Put it one way it won’t work. Flip it over and it works.
  3. Aug 2, 2022 at 5:06 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Im guessing the key mechanism is not seated properly. This happened to me when I replaced my door handles - just pull out the mechanism and try to seat it again, test that it works before you re-attach the screws.
    Here's a video on how to remove the key mechanism.
    https://www.youtube.com/watch?v=-3_MQKgXhok
    BRICK916[QUOTED][OP] likes this.
  4. Aug 2, 2022 at 5:54 AM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    The first time I changed out my driver's door lock mechanism I did not get the lock cylinder fitted into the new one and the key would not work. The key would turn but it didn't do anything. The second time I installed it, I did it correctly and made sure the rod was fitted into the back of the mechanism. Now that I know how easy it would have been to take the lock cylinder out, I would have removed it.
  5. Aug 2, 2022 at 2:42 PM
    BRICK916
    C
    3 inch litt
    Makoy339 was spot on. Took the lock out rod dropped I guess when installed. Reinstalled works just fine. Thanks guys
