Driver side power seats have zero power
Discussion in '2nd Gen Tundras (2007-2013)' started by Maddux10100, Dec 25, 2019.
  1. Dec 25, 2019 at 11:56 AM
    Maddux10100
    Maddux10100 [OP] New Member
    Barry
    2007 Tundra 4x4
    I’ve looked online and it says some repairs are $4500 any help out there?!?
  2. Dec 26, 2019 at 2:12 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    What checks have you made....fuses, plugin under seat etc ?
    NewImprovedRon likes this.
  3. Dec 26, 2019 at 2:39 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Start with the fuse.
  4. Dec 30, 2019 at 7:12 PM
    Maddux10100
    Barry
    2007 Tundra 4x4
    changed fuse. it moved a little bit then blew the new fuse
  5. Dec 30, 2019 at 7:21 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Sounds like you have a broken wire pinched somewhere. Did you check the wiring?
  6. Dec 31, 2019 at 2:53 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Sounds like that motor or something related....motor itself, gears binding, possible blockage. Mind sharing more about the truck....AC DC Reg, Limited ?
    Does it have more than back and forth settings ? If so, do any of them work ? It might require you to remove seat and check it more closely from underneath and even apply temp power to look at motor action if you feel comfortable in doing that kind of work. Sure is better than paying that $4500 figure you mentioned :eek2:
    Maddux10100[OP] likes this.
  7. Jan 9, 2020 at 3:55 PM
    Maddux10100
    Barry
    2007 Tundra 4x4
    Haven’t yet
  8. Jan 9, 2020 at 3:57 PM
    Maddux10100
    Barry
    2007 Tundra 4x4
    Has from back, then back moves back then maybe lumbar?
