Driver side kick panel help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bracky, Oct 13, 2020.
  1. Oct 13, 2020 at 6:17 PM
    Bracky
    Bracky [OP] New Member
    2017 Tundra Limited with TRD Package
    B12F27E0-7FF6-4D16-9E87-67C857F7DA97.jpg CB9A134B-ECF1-406A-8B63-B22EDC896D8A.jpg I can’t for the life of me get this to stay closed. It wants to work it’s way slightly open.
    is there a trick?
  2. Oct 13, 2020 at 6:22 PM
    They are a pain in the rear. Give it a good pop with your palm to make sure that top clip is seated into the hole.
    mountainpete likes this.
  3. Oct 13, 2020 at 6:29 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, them things are a bugger. They're kind of trial-and-error. The 2nd Gen ones seem to go in at an inboard toward outward 45 degree angle. Also, it helps to have removed the long rocker panel section as seen at the bottom of the second picture. That will give you some additional wiggle room of the kick panel.
  4. Oct 13, 2020 at 6:31 PM
    3rd gens are the same way.
    Wynnded[QUOTED] likes this.
  5. Oct 13, 2020 at 6:36 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Okay, the door seal/gasket in the pictures look a little different than what I'm remembering off the top of my head of my truck. So I thought I'd put in sort of a disclaimer. :)
  6. Oct 13, 2020 at 7:27 PM
    Bracky
    I found the trim panel that connects to it from the floor to be a little bit of a pain to get on too.
    for the kick panel I feel like I have beat on that thing and just can’t get that white clip to seat. It’s really annoying my OCD to not get that panel completely closed!
  7. Oct 13, 2020 at 7:41 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    I had better luck putting the clip in the hole then sliding the panel over the clip.
    Hugemoose, Bammer and Wynnded like this.
  8. Jun 7, 2022 at 6:04 AM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    I seem to have lost the threaded nut that retains this kick panel against the carpet, anyone have a part number for this?
    EDIT: I believe it is this KICK PANEL FRONT CLIP - TOYOTA (90467-06155)
  9. Oct 7, 2022 at 11:10 AM
    icodeintx
    icodeintx New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    Mine is exactly the same and the plastic that holds the clip is damaged now so I can't put another clip in it. I'm considering putting a nutplate in there and drilling a hole through the kick panel because that clip is $hit.
  10. Oct 7, 2022 at 11:22 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That certainly looks like it..
    It screws off but pushes on.
    Most of the time when I take panel off, the lower clip stays in the truck body.
    I have to pull it and reset it in the panel..
    NewImprovedRon likes this.
