Driver side headlight does not work but high beam does
Discussion in 'Electrical' started by Sithways, Feb 8, 2023.
  1. Feb 8, 2023 at 3:37 PM
    Sithways
    Sithways [OP] New Member
    Johnny
    2003 Toyota Tundra
    Hello! I have a 2003 Toyota Tundra, V6 2, wheel drive. My driver side headlight does not work, but the bright (high beam I believe it is called) does. On the passenger side both regular and high beam light works. I’ve changed the bulb, fuses and tested the relay and it works.
    Any help with be much appreciated… thanks in advance!
  2. Feb 8, 2023 at 5:11 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    If you have verified fuses ect get the voltmeter out and check for voltage at the wiring plug to the headlight.
    If you have 12v at the headlight connector your problem is with the bulb or connection into the headlight.
    If you don’t have 12v at the headlight connector you need to start looking at fuses again, or broken/damaged wiring.
    Sithways[OP] likes this.
  3. Feb 8, 2023 at 7:12 PM
    Sithways
    Johnny
    2003 Toyota Tundra
    Thank you for your assistance. Another quick question, can the slots that I put the fuses in go bad? I put new 10A fuses in the slots but they are super loose in there unlike the other 10A fuses for the passenger side headlights. I put the new ones in those to see if it was just the fuses which were to small, but they fit snug in those ports. Thank you!
