Driver Side Door Latch
Discussion in '1st Gen Tundras (2000-2006)' started by arlail76, Feb 15, 2021.
  1. Feb 15, 2021 at 1:53 PM
    arlail76
    arlail76 [OP] New Member
    Andrew
    Stock 2004 Toyota Tundra Double Cab 2WD
    Does anyone have a spare driver side door latch laying around? Seems like every time I open mine now, I have to flip it up so I can close the door. It’s really getting annoying...and it makes a hell of a racket if I forget to flip it up.
  2. Feb 15, 2021 at 2:59 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It's probably just dirty. Hose it down with WD40 and work it back and forth. Once it's free spray it with since white lithium.
  3. Feb 15, 2021 at 7:26 PM
    arlail76
    Andrew
    It had not been working good, and I sprayed it with WD-40, and now it works worse
  4. Feb 15, 2021 at 8:37 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    WD-40 is not a lubrication product, it is a solvent. You can use it to de-grease your latch as @Festerw suggested but you will need to apply a layer of lubricant such as white lithium after.
    2006Tundra and Randy Morton like this.
  5. Feb 16, 2021 at 2:21 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Takes more than a quick spray. I'm talking like a half can sprayed at it while you work the latch back and forth.
    It likely works worse now since you dislodged some crud.
    Like @des2mtn said WD40 is a shit lubricant but all the solvents work well for cleaning.
  6. Feb 22, 2021 at 12:04 PM
    arlail76
    Andrew
    When I open my door, this is what the latch does.
    I’ve used an obscene amount of WD-40 to flush this thing out and re-lubed it with lithium grease after, and worked it over to get it in there good. The damn thing just will not pop back up like it should. I have to use my finger and pop it back up so it looks like this and I can close the door...and I have to slam it usually:
  7. Feb 22, 2021 at 12:23 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Does it feel springy at all or does it just feel loose when you flip it up?
  8. Feb 22, 2021 at 1:45 PM
    arlail76
    Andrew
    It’s not loose...fairly firm when I flip it up.
    Also, it will be at different levels of that each time I open the door. Never the exact same
  9. Feb 22, 2021 at 1:53 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    So, funny story. I just bought two doors for an 01 sequoia because I needed the latch for the passenger side and window switch for the driver's side. I stripped off all the other parts to possibly sell them. So I have a driver's side door latch that I don't need. I'll double check, but the DC and sequoia front doors are the same so it shroud work for you. DM me if you're interested.
  10. Feb 22, 2021 at 3:35 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Could be the spring has broken but I've seen some pretty crapped up too and the only way to clean them is removing the whole assembly and soaking it in parts cleaner.
    Jack McCarthy likes this.
  11. Feb 22, 2021 at 5:24 PM
    arlail76
    Andrew
    I sent you a message
  12. Feb 22, 2021 at 7:32 PM
    arlail76
    Andrew
    I wonder if a can of brake cleaner would clean it out. I just was trying to avoid taking it out to clean it
  13. Feb 23, 2021 at 5:08 AM
    Professional Hand Model
    Hand Protectors
  14. Feb 23, 2021 at 5:14 AM
    arlail76
    Andrew
    Dangit!
  15. Feb 23, 2021 at 9:31 AM
    rock climber
    You can try cleaning it, but there's a little plastic sleeve that wears out and that's what it looks like happened to yours (the yellow cover piece that's scratched up). I tried cleaning both of mine first, but ended up replacing them.
  16. Nov 19, 2023 at 7:26 AM
    PastorGman
    PastorGman New Member
    Rock Climber, you are 100% right. I was looking at mine on the passenger side front door of my 04 Tundra DC and there is a plastic sleeve that is messed up. That side of the truck takes most of the Central Texas sun and heat so that could've been what caused it. Is this a part that can be replaced or is it integrated into the door itself? If you know of a part number then I would really be grateful.
  17. Nov 19, 2023 at 8:12 AM
    I checked the parts diagrams at EPC-DATA's site, and it shows the latch assembly as one complete unit, with no internally serviceable parts.
    There's a chance you may be able to rebuild it? All I know is, whatever you do, don't buy non-OEM on that part. Two people within the last 6 months bought replacement latches off scAmazon and wound up with a door that wouldn't open. One paid $700 for a body shop to pop the door and replace the latch, the other hired a locksmith who couldn't pop it, then ended up damaging the door skin to get their door open. I wouldn't buy on scAmazon or fleaBay either, you never know if what you're getting is actually authentic.
  18. Nov 19, 2023 at 11:40 AM
    PastorGman
    Thanks, Rock Climber. I purchased one from a salvage yard and it works good but that was for the driver side door. Definitely would not buy from scAmazon this part. I guess once I get one I will spray it with lithium grease before I install it. Thanks for the advice!
  19. Nov 21, 2023 at 5:44 AM
    Danzig
    Danzig New Member
    06 tundra
    Thats what i do, lithium works well
