Driver side door handle replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kray, Oct 20, 2018.
  1. Oct 20, 2018 at 12:54 PM
    Kray
    Kray [OP] New Member
    2015 tundra
    Ok, heres the deal. Someone tried to break into my girlfriends truck and and busted the lock out and broke the handle. I know the replacement is pretty straight foward, but what im having an issue with is how the lever release is supposed to be orientated. (does that make sense?) I guess i could take the passanger side off to get an idea. I was hoping someone could point me in the right direction.
  2. Oct 20, 2018 at 4:04 PM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Not sure what you mean. Need pics
  3. Oct 20, 2018 at 4:12 PM
    Kray
    2015 tundra
    Ok I'll get some pics. The handle is just flopping, no tension at all. so whatever latch its supposed to catch on to open the door there not connecting. Thank you for the reply
  4. Oct 20, 2018 at 5:56 PM
    TheBeast The Beach
    remove door panel from inside. there should be a green wire you attach to the handle.
