Driver side door handle/help getting in?
Discussion in '2.5 Gen Tundras (2014-2021)' started by widetrax, Oct 4, 2020.
  1. Oct 4, 2020 at 12:39 PM
    widetrax
    widetrax [OP] New Member
    lester williams
    Meridian Ms
    2021 1794 tundra
    I always wondered why they left the handle off,, I'm kinda old and need a little help getting inside the truck. [76yo] I really need one to get in with, anybody offer one that fits?? Thanks in advance,,,
  2. Oct 4, 2020 at 12:43 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    A lot of us on here have added that. They are available from the dealer. We have a few vendors here who sell them also.
    10 minute install. Very easy.
    tlakeTundra and Tundyfundy like this.
  3. Oct 4, 2020 at 12:46 PM
    Boerseun
    Ferdie
    Sarasota Florida
  4. Oct 4, 2020 at 1:19 PM
    widetrax
    lester williams
    Meridian Ms
    2021 1794 tundra
    OK then,, thanks a lot guys. Guess I'll get one on here.
  5. Oct 4, 2020 at 1:21 PM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
  6. Oct 4, 2020 at 1:27 PM
    @Roman
  7. Oct 4, 2020 at 1:29 PM
    Doctor Flex
    Utah
    2020 White 1794 TRD
    Roman has the A pillar and Handle, but I believe you have to source the rest of the parts from HD. Sparks has it as a set, all parts included. If you are lazy like me and don't want to hunt through the drawers of hell, go sparks for this one.
  8. Oct 4, 2020 at 1:30 PM
    Makes sense:thumbsup:
  9. Nov 16, 2020 at 1:49 PM
    TSands83
    TSands83 USAF Jet Engine Mechanic
    OKC, OK
    2015 Attitude Black Tundra Platinum CM 4x4
    Black TRD Pro headlights, iHacker LED Plug N Play harness, black LED fog lights, TRD Pro grille, TRD skid plate, TRD front and rear sway bars, TRD Pro Fox shocks, TRD intake, TRD dual exhaust, Lexus/Toyota aluminum oil filter cap, Stahlbus oil drain valve, black Fuel Offroad Pump 20x9+20 wheels, color matched mirror caps and door handles, stubby antenna, black tube steps, driver side assist handle, Rago dash plate with ICS backing plate, SR black interior door handles, SR black dash center panel, Tacoma/4Runner left and SR right black steering wheel switches, black steering wheel emblem, black TRD shift knob, AJT Designs shifter and cup holder bezels and HVAC control knobs, Husky floor mats, Trail Edition bed storage boxes, bed LED strip lighting, bed mat, Charvonia Design Billet Tie-down Anchors, 38 gallon fuel tank, RCI fuel tank skid plate, AVS window deflectors/visors, Recon taillights, Recon smoked 3rd brake light, GTR Lighting interior and exterior bulbs, Morimoto mirror puddle lamps, center console wireless charging tray, RAM Mounts Quick Grip wireless charger, Alpine iLX-F509/DVE-5300/KCX-630HD/DVR-C320R, Maestro RR, Garmin Drivesmart 65 & Traffic, Llumar FormulaOne Stratos Nano-Ceramic Window Tint. More to come...
    Instead of using the included SAE bolt and oversized u-nut from Lowes that comes in the Sparks kit (or running around sourcing hardware on your own if you only got the trim and handle), I decided to keep it OEM metric hardware. There's my OCD, I know.
    90080-11354 Bolt, with washer (same as passenger side '14+, both sides '07-13)
    90179-06349 U-nut (it shows to be from the license plate holder)
    Don't forget the little plastic clip that wasn't included with my A-pillar trim. You don't necessarily need it, but it might reduce rattle and it will hold your trim in place during install until you get the bolts in. In my case, there was a little tab on the back of the trim that wouldn't line up with the slot cutout in the pillar sheet metal, bulging the center of the trim. If you need it, the part number is
    62217-04010 Clip, front pillar garnish (same as passenger side '14+, both sides '07-13).
    Obviously, Sparks and Cool Springs are cheaper.
    I think that I used some double-sided tape (Duck or Gorilla) between the u nut and pillar bracket and wedged a spare washer under the tab on the back side to hold it in place during install (the washer keeps it from rattling once tightened since the u-nut was meant for the thickness of a plastic part rather than sheet metal).
    I used my old trim to make a template for the cutout on the new trim.20201116_150906.jpg 20191225_213148.jpg 20191225_214200.jpg
  10. Nov 16, 2020 at 2:27 PM
    Megaman
    Megaman New Member
    2020 Tundra Limited DC 4X4 TRD Silver Sky Metallic
    Just put mine on last week. Just didn't want to continue pulling myself up with the steering wheel.....can't be good for it. Costs way more than it should, but works great. All 4X4's should have had one from the factory. Literally every other door on the truck came with one!!
    TSands83 likes this.
  11. Nov 16, 2020 at 2:28 PM
    Doctor Flex
    Utah
    2020 White 1794 TRD
    And every other half ton truck out there it seems.
  12. Nov 16, 2020 at 2:44 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Easy mod.
    I didn't use it when I had my running boards on. But since those came off, I use it all the time now
  13. Nov 16, 2020 at 4:55 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Doesn’t look like Sparks sells the kit anymore...
  14. Nov 16, 2020 at 5:06 PM
    TSands83
    OKC, OK
    These are the main parts that would've been in the kit.
    Windshield Pillar Trim (62220-0C050-B0) × 1
    Assist Strap (74610-0C082-B0) × 1
    You should still be able to find the parts in their oem parts section by part number (or Cool Springs). Sparks only put this in a convenient kit packaged with some hardware from Lowes, nothing different. Some folks even found the trim and handle on megazip.
    For hardware, see my post (post #9 of this thread).
    Don't forget, Black Friday is right around the corner. Might be some deals soon.
  15. Nov 16, 2020 at 5:49 PM
    First World Problems
    First World Problems New Member
    2021 Tundra TDR Pro - Lunar Rock
  16. Nov 28, 2020 at 11:41 AM
    splitfuse
    splitfuse Dr. Tundra
    AB-CAN
    2020 Cement Tundra Crew TRD
    Thanks for the tips everyone! Got the parts on order just wondering if anyone can elaborate on how the pillar air bag interacts with the a pillar garnish & handle.
    In the event of air bag activation does the entire plastic moulding pop off or hinge out of the way?
    Does the addition of the handle affect air bag inflation any way?
  17. Nov 28, 2020 at 11:43 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Shouldn't impact it - the airbag will blow out along the seam of the pillar garnish and the frame itself. The Gen2 trucks had the handle and the same airbag. I'm pretty sure the primary reason the deleted it was for field of view - there are times when that handle does block your vision a little (think smart car hanging out in the left lane off your front wheel).
    splitfuse and Doctor Flex like this.
  18. Nov 28, 2020 at 11:51 AM
    Doctor Flex
    Utah
    2020 White 1794 TRD
    I think this is correct, the blind spot thing. I have my seat adjusted based on my build, so that the pillar handle is in line with the pillar itself from a field of view standpoint, so it doesn't seem to affect my view. However, I can see how it could. Plus, the passenger side is the same with the handle and seems to work fine from an airbag standpoint. Obviously field of view isn't a safety issue for the passenger.
  19. Nov 28, 2020 at 1:17 PM
    splitfuse
    AB-CAN
    Thanks for confirming guys, makes total sense
  20. Nov 28, 2020 at 1:26 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I thought they removed it for safety, hitting drivers head against it in a crash.
    On the flip side, if it's safe for passenger why not driver too? Toyota probably justified it by most times they are driven solo.
    I put it in mine and love it. Doesn't affect field of view
    splitfuse likes this.
  21. Nov 28, 2020 at 1:36 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I had more than a few times in my ‘08 that I noticed it leaving me with a less than ideal view to the front left (more so I noticed the improvement in my ‘21). I may add it back for convenience of getting in/out, but I guess I don’t consider it so much a MUST HAVE.
  22. Nov 28, 2020 at 2:05 PM
    Doctor Flex
    Utah
    2020 White 1794 TRD
    That's good speculation also. I guess we may never know. Maybe I should wrap it in a pool noodle, just to be safe.
    Bammer, RainMan_PNW and splitfuse like this.
  23. Nov 28, 2020 at 2:06 PM
    splitfuse
    AB-CAN
    Personally I found it to be a bit costly but the black friday 20% off with megazip helped justify the upgrade for me. My big goal with the handle is to avoid wearing out the side of my seat bottom like I did in my 2nd gen Taco. I did an OEM seat skin swap once at yr 7 and when I sold it on yr 13 it needed to be done again...
  24. Dec 1, 2020 at 9:29 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    I just used the kit from sparks, a little pricey but it has everything you need. I don't notice any loss of visibility but depending on where your seat is adjusted that could change.
    The reference I read about why the removed it (I don't have a link) was to do better on a particular crash test metric where there was a possibility of the drivers head hitting the handle. I'll take the handle and a set of running boards and just wear my seat belt. It makes it much easier to get into and out of the truck when you're old, or old and broken, or old broken and fat.
  25. Dec 1, 2020 at 9:33 AM
    Megaman
    Megaman New Member
    Good thought, but they install them on other trucks that have air bags in the A-pillars....and I assume all trucks go through the same crash tests. - Toyota is just "cheaping" out....IMO
  26. Dec 1, 2020 at 9:55 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    They did do it for "safety" except the "safety" was to not look bad compared to the competition on a mostly made up crash test. Instead of doing some real engineering to keep the handle and "improve" the safety they just removed it. I expected better from Toyota but at least they didn't remove the mounting bracket underneath so that the prior stock part would no longer bolt on.
    Megaman[QUOTED] likes this.
  27. Dec 1, 2020 at 6:19 PM
    AGuyFromNC
    AGuyFromNC New Member
    Nick
    2020 Tundra CM TRD Offroad
    Is there only one part number for this? Different p/n for grey or tan?
  28. Dec 1, 2020 at 6:32 PM
    Megaman
    Megaman New Member
    No -there's 2 colors. The gray and beige colors. They have different letters on the end of the part #'s to denote which color it is.
  29. Dec 1, 2020 at 11:08 PM
    TSands83
    OKC, OK
    Drainbung likes this.
  30. Dec 2, 2020 at 3:03 PM
    AGuyFromNC
    Nick
    OK. Thanks for the help.
    I didnt check out the Sparks link. I figured i'd call a local wrecking yard first.
