Driver seat sliding
Discussion in '3rd Gen Tundras (2022+)' started by TundraTT1794, Oct 12, 2022.
  1. Oct 12, 2022 at 1:16 AM
    TundraTT1794
    TundraTT1794 [OP] New Member
    The driver seat slides back when engine turns off and only sometimes slide back into memory spot when turning on engine. I would have to readjust the seat when this happens. Anyone else having this issue?
  2. Oct 12, 2022 at 8:12 AM
    xc_tc
    xc_tc New Member
    You can turn that off in the settings. It’s the easy entry/exit.
  3. Oct 12, 2022 at 8:38 AM
    TundraTT1794
    Problem is it doesn’t work when it’s on.
  4. Oct 12, 2022 at 8:42 AM
    xc_tc
    xc_tc New Member
    Sounds like a profile issue? I don’t know, I don’t have this problem.
  5. Oct 12, 2022 at 9:42 AM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    Try moving the seat (manually) to the maximum positions .Front ,back,up,down then reset your memory.
  6. Oct 12, 2022 at 5:57 PM
    Kkwatz
    Kkwatz New Member
    yeah, I had similar issues when my profile wasn't setting properly. seems like it keeps different memories for different profiles. I just set mine and the guest to be the same and haven't had a problem since
