Driver Grab Handle Squeak
Discussion in '2.5 Gen Tundras (2014-2021)' started by Brimaster, Nov 8, 2017.
  1. Nov 8, 2017 at 8:46 AM
    Brimaster
    Brimaster [OP] New Member
    2017 Magnetic Gray Metallic DC TRD
    Added the grab handle but now that it is getting cold it is starting to squeak. Pulled it out and checked and not sure if it is rubbing the wire harness or what. So before I start to add foam weatherstrips or something thought I would ask if anyone else that added the handle has encountered the same thing and was able to resolve it.
    Thanks in advance for the guidance.
  2. Nov 8, 2017 at 8:53 AM
    Brimaster
    Thanks!! I'll give that a shot...
    NewImprovedRon likes this.
  3. Nov 8, 2017 at 11:04 AM
    No issues with mine...came off a '13 CM
  4. Nov 20, 2017 at 2:26 PM
    Brimaster
    Well after so more investigation seems to be the cabling at the top of the piller that is hitting the upper trim that the creak is coming from when the temp drops. Pushed the cabling tighter to the piller and added some one sided adhesive foam weatherstripping along the cable harness so see what happens. If that does not help then I'll give RowdyRon's tip a try.
  5. Nov 20, 2017 at 7:22 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I didn't know 2nd gen grab handles will fit 3rd gens... Interesting!
  6. Nov 20, 2017 at 7:28 PM
    Yes they fit...mine came off a '12-'13 CM
  7. Nov 20, 2017 at 7:48 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good to know.
