Driver door lock turns with key but dosent
Discussion in '2nd Gen Tundras (2007-2013)' started by 10 Bears, Aug 22, 2023.
  1. Aug 22, 2023 at 11:05 AM
    10 Bears
    10 Bears [OP] New Member
    11 CREW 5.7
    None at the moment
    Lock or unlock unless I use the remote key fob meaning the actuator works ?
    2011 Tundra Crew 5.7 202k
    The tailgate does the same. Is this a issue of accessing the tumbler loosening it with tools/ hammer and lubricant....or I'm gonna have to replace the whole lock unit ??
    Anyone else experience this before ?? It happened to my Tacoma passenger side after only 2years new, admitably I seldom used the key on that side since it had remote locks.
    My biggest fear is loosing the fob or battery going dead and can't open the door. Don't mind going to a auto locksmith but if it's a matter of simple mechanics I'm willing to ruin it trying to fix it since It's not working anyway...lol
    By the way I haven't had luck finding YouTube videos on this ??
  2. Aug 23, 2023 at 5:32 AM
    eddly
    eddly New Member
    tundra sr5 5.7l
    ('07 tundra sr5)my tailgate lock wouldn't move using key,sprayed wd40 into it (soaked it) kept gently trying to move tumbler using key & it finally starting working.
  3. Aug 23, 2023 at 12:27 PM
    kos221
    kos221 New Member
    2007 4X4 DC
    I had that issue and it turned out the cause was a worn out key. The lock (driver door, glove box and tailgate) worked fine with my back up key. Can you take that key out of the ignition while the vehicle is running? If so, the key is worn out. A fresh cut key from the dealership should fix it. If you feel the need to lubricate the lock assembly, use a graphite lubricate. Regular WD-40 is not recommended because dust will get stuck to it and cause more issues in the future.
  4. Aug 23, 2023 at 5:08 PM
    eddly
    eddly New Member
    tundra sr5 5.7l
    Thanks !
  5. Aug 30, 2023 at 10:27 PM
    10 Bears
    11 CREW 5.7
    None at the moment
    Wow. I think there's 5 different wd40 variants now. Far out.
  6. Aug 30, 2023 at 11:12 PM
    10 Bears
    11 CREW 5.7
    None at the moment
    You called it.
    So the truck came with two keys and Fobs. After reading this ...again I took key #2 with some pb blaster sprayed on the key and presto....the driver door and tailgate now lock and unlock. Now to get Fresh key made.
    Thanks kos221.
  7. Aug 31, 2023 at 9:16 AM
    kos221
    kos221 New Member
    2007 4X4 DC
    You are welcome. I am glad I was finally able to contribute something to this forum that I have learned so much from.
    10 Bears[OP] likes this.
