Driver door actuator
Discussion in '2nd Gen Tundras (2007-2013)' started by Franklbecerra1, Jun 8, 2021.
  1. Jun 8, 2021 at 7:00 PM
    Franklbecerra1
    Franklbecerra1 [OP] New Member
    2007 Toyota Tundra
    Hello all 2nd gener’s. I’m hoping someone out there might have encountered the same issue I’m having with the driver side door of my 2007 Tundra Limited extended cab. The driver side door stopped unlocking about a month ago with either the remote key fob or the interior unlock switch. The only way the door unlocks now is with the key, manually unlocking the door from the inside or pulling the handle from the inside of the door. The interesting thing is that it still locks using all mechanisms (remote and interior unlock switch). Some DIY videos I found suggested making sure that the connectors to the door console were seated properly and they were, so bought a Toyota actuator replacement and installed it. The same problem exists with the door not unlocking with the remote and interior unlock switch. Does anyone have any experience with this problem and can you suggests the next thing to troubleshoot? Appreciate you assistance.
  2. Jun 8, 2021 at 10:44 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Sounds like switch is bad.
  3. Jun 9, 2021 at 6:48 AM
    Franklbecerra1
    2007 Toyota Tundra
    Thanks for the response Delandshark. Would you be able to provide more detail of which switch you’re referring to?
  4. Jun 9, 2021 at 7:02 AM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Or bad ground\broken wire somewhere.
  5. Jun 9, 2021 at 8:18 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    I was talking about the driver door lock switch. You can remove it and test with an ohm meter. That’s what I would do anyway. image.jpg
    You’ll have to locate a diagram to know which wires go to the door switch.
  6. Jun 9, 2021 at 8:21 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    The door lock actuators are known to go bad on Toyotas. You can either replace the whole actuator for $100+ or there are videos about how to change the motor inside of them for about $5. I've had to do the drivers door of my 2016 and now have another one that is acting up.
    Danny3737 likes this.
  7. Jun 9, 2021 at 8:38 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    I think OP did that.
  8. Jun 10, 2021 at 12:36 AM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Does the actuator make a noise when you try to unlock it? If yes, you might just need to lube up the internals. If no, then probably electrical.
  9. Jun 10, 2021 at 4:15 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Yep, I missed that when I read through it the first time.
  10. Jun 10, 2021 at 6:43 AM
    Franklbecerra1
    2007 Toyota Tundra
    Thanks for the added details and picture Dalandshark. The driver side door (lock/unlock) switch works on all doors except the driver door. With that being the case do you still think that this switch would be the issue?
  11. Jun 10, 2021 at 7:09 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Good point. I would look into the wire from the actuator to switch.. it could be something in the plastic housing of the door switch though (not having seen the diagram) or connection into the door switch module.
  12. Jun 10, 2021 at 7:29 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Are you sure you hooked the bars back up when you installed the new actuators?
  13. Jun 10, 2021 at 8:17 PM
    Franklbecerra1
    2007 Toyota Tundra
    Both cables are hooked back up.
  14. Jun 10, 2021 at 11:12 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    My driver door lock actuator died at 26k miles so it isn’t unheard of that the motor shits the bed.
  15. Jun 11, 2021 at 12:35 PM
    AJW
    AJW New Member
    JBA shorty headers / Koyorad stainless radiator / Belltech street performance lowering struts,shocks / Airlift 72000 wireless air leveling compressor / Firestone air bags.
    I had the same problem with my 07' a month ago. However, my tundras key fob wouldnt lock the drivers side door. Did a search in this forum and found out it was the door actuator. Instead of spending 380$ on a new OEM door actuator from Toyota i found a youtube video of a guy that just replaced the little motor ($6 on Amazon) in your existing actuator that fixed the problem. Been over a month now and no problems.....
  16. Jun 11, 2021 at 4:16 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Please note: He replaced his actuator already.
  17. Jul 12, 2021 at 7:10 PM
    MICHAELLI
    MICHAELLI New Member
    I have the total the same problem. Did you solve the problem yet?
  18. Jul 12, 2021 at 7:12 PM
    MICHAELLI
    I think the problem is from unlock wire(blue -----pink). There is no power.
