Drive shaft rattle
Discussion in '1st Gen Tundras (2000-2006)' started by Cody06tundra, Jan 2, 2021.
  1. Jan 2, 2021 at 12:40 PM
    Cody06tundra
    Cody06tundra [OP] New Member
    Cody
    2006 Tundra Crew Cab SR5 4.7L
    So I've had this rattling sound coming from somewhere under the front. Whenever I would stop there be a light metallic clink like a piece of metal was coming forward and stopping whenever I would drive. And I found out that there is something between the drive shaft and the transmission that has been causing the noise. Any ideas on how to fix it?
    potoghi likes this.
  2. Jan 2, 2021 at 12:50 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Its a dirt/rock shield that has come loose. Remove driveshaft and tap it back onto the yoke.
    You can add some adhesive or epoxy if you want. It goes on that 1/4-3/8" or so collar at the base of the splined portion.
  3. Jan 2, 2021 at 1:27 PM
    Cody06tundra
    Cody
    Awesome!! Thanks so much. Gonna get my u joints done at the same time.
    Much obliged!
  4. Jan 2, 2021 at 6:23 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Perfect time for new u-joints!
