Drive shaft blues
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Nov 24, 2019.
  1. Nov 24, 2019 at 7:53 AM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    my 80K Tundra is new to me. Unknown history on the car.
    I have been experiencing a whistling sound from the drive train
    while deceleration. If I add power, the sound goes away. I crawled under
    the car and found nothing. No visual problems.
    I still felt that there was something wrong. I sent the truck to my local
    guy for closer inspection. Drive shaft was removed and sent to driveline
    shop. The report came back as in sad shape. Bent,out of balance, center support
    unit failing, U joints bad.
    Anyway, I was very surprised that this low mileage truck needed a driveshaft overhaul.
    Either way, truck drives like new.
  2. Nov 24, 2019 at 7:58 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    That is surprising. Maybe it's been in deep water in the past and previous owner didn't grease as needed?
    Or maybe that driveline shop just wanted to make some money?
    Either way glad you got it sorted out. These are great trucks and can be problem free with proper maintenance.
  3. Nov 24, 2019 at 8:03 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Even if only at 80k, it's still 15 years old. If it was never greased I can beleive it. Still unfortunate though. Hopefully the shop doesn't charge you a fortune. I only paid around $120 to have my drive shaft rebalanced and they said my u joints were fine.
  4. Nov 24, 2019 at 8:24 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    My Dad has a 2006 DC.
    His is 4 wheel drive, mine is 2 wheel drive.
    Surprisingly, only the 4 wheel drive Tundras have driveshaft
    Grease zerks! My rebuilt driveshaft has zerks now.
    My XSP is from Louisiana and prolly got dunked under the
    water more than once. I don’t have any watercraft so prolly good to go.
  5. Nov 24, 2019 at 8:31 PM
    Aerindel
    Aerindel New Member
    Montana
    Just an FYI for anyone who hasn't done it, U joints only cost about $20-50 for the parts and you can replace them yourself at home in about half an hour if you have or rent the tools, which mostly just means having a big bench vice.
  6. Nov 25, 2019 at 5:47 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The only time greaseable joints are better is if they're actually greased. The average person isn't going to grease them as often as necessary. Which reminds me that I need to grease mine.
    A quality sealed joint IMO is preferable for a DD. It's not unusual for a sealed factory joint to go 150-200k.
    MS22 and bmf4069 like this.
  7. Nov 25, 2019 at 10:52 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I am surprised that the shaft was bent, everything else makes sense if it wasn't maintained.
  8. Nov 26, 2019 at 5:24 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Mine are over 300k.
  9. Nov 26, 2019 at 5:30 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    My 1997 T100's (4WD) are at 263,000 and doing great. Get greased regularly.
    MS22 likes this.
