Drive Monitor Switch only Sonar working
Discussion in 'General Tundra Discussion' started by kwjsimpson, Nov 13, 2020.
  1. Nov 13, 2020 at 6:22 PM
    kwjsimpson
    kwjsimpson [OP] New Member
    Kansas
    2013 Tundra Crewmax SR5 5.7 V8
    18” Mayhem wheels, remote start
    Hello all! Hope someone here has ran into this issue and possibly have some ideas. I’ve searched the forums and found some tips, but unfortunately still have the issue. I have a 2013 Crewmax SR5 with Info, Select, Setup, and Sonar on the Drive Monitor Switch. Unfortunately only the sonar button does anything. Here’s what I’ve done so far.
    I removed the switch, took it apart and verified contacts are in working order. Perhaps overkill, but ya know.. I verified I have all 8 wires at the switch AND that all wires exist at the junction under the steering column. I verified with the meter that I am getting good signal when pushing the buttons (Info, Select, & Setup) from the switch all the way through the junction plug to the next set of wires. I have also verified that the display on the dash (the one not in the gauge cluster) has options to show avg mpg, instant mpg, etc. via flashlight test. The temperature is at least set to Fahrenheit and not Celsius, so that’s a plus for me!
    What I have NOT done is get crazy enough to check the wiring all the way up to the display because I assume that means removing the dash and I have no idea where to start.
    I can’t change the temp to show Celsius (again not needed for me) and can’t flip through avg and instant MPG, but don’t really care much anyway as I bought a truck on purpose and knew what I was getting into! It’s more the principal that something that should work doesn’t and I want it to work even if I won’t use it.
    So..any ideas? Could the ECU have lost its programming for allowing the functions to respond to the buttons? Am I looking at removing the dash if I really want to get it working? Any thoughts or advice welcomed!!
  2. Nov 21, 2020 at 8:51 PM
    kwjsimpson
    Kansas
    Bump.. Anyone?
  3. Jan 24, 2021 at 11:12 AM
    Truckernick7
    Truckernick7 New Member
    2013 Toyota Tundra sr5 TRD
    None
    I just bought the same truck and have the same issue. Have you came up with anything?
  4. Jan 24, 2021 at 1:34 PM
    kwjsimpson
    Kansas
    Nothing yet, but I have an appointment with the dealership this coming weekend for it, so hopefully will have a resolution soon. Will post what they come up with.
  5. Jan 30, 2021 at 2:25 PM
    kwjsimpson
    Kansas
    Unfortunately, the dealer I bought it from couldn’t figure it out either and suggested I take it to a Toyota dealership. So that’s my next steps. I’m wondering if it’s a loose wire at the display plug or something as all else checks out. Anyone know if the display can be removed without removing the dash?
  6. Oct 19, 2022 at 6:02 PM
    sch2656
    sch2656 New Member
    I have a 2013 Double cab base model, got all 8 wires and have same issue. I can toggle between celsius and fahrenheit but nothing else.
  7. Oct 19, 2022 at 6:39 PM
    Original thread. Some trucks needed an additional 2 wires added for it to work.
  8. Dec 15, 2022 at 1:22 AM
    detco
    detco New Member
    2013 Tundra SR5 TRD
    Just bought a 2013 SR5 TRD and have same issue. Anyone have any luck figuring this out?
