Drilling into composite bed
Discussion in '3rd Gen Tundras (2022+)' started by geewizard, Apr 3, 2024.
  1. Apr 3, 2024 at 6:56 AM
    geewizard
    geewizard [OP] New Member
    E Washington/N Idaho
    2023 1794 TRD OR
    I need to add some D-rings on the side of my bed near the molded-in 2x4 slots. This is to hold some gas cans so no heavy weight at all.
    It doesn't look like I can get to the back of the bed to put in a backing washer or plate. Is there any reason I cannot use a threadsert?
    Or is anything like this going to void my warranty?
    2023 1794
  2. Apr 3, 2024 at 7:34 AM
    Red13
    Red13 New Member
    2022 SR5 Crew Max TRD Off Road Army Green
    I drilled into the side to mount a pelican box using a threadsert. Holding up pretty well.
  3. Apr 3, 2024 at 8:00 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Only thing I see voiding on your warranty is if the bed cracks where you drilled into it, so drill away. Also if you crawl under the truck you do have decent access to the side of the bed. Just poke your head inside your fender and you can nearly see the entire bed side (the front of the bed where it meets the cab not so much).
  4. Apr 3, 2024 at 8:43 AM
    ullmsie
    ullmsie New Member
    Limited DC TRDOR
    People have recommended using a stepped drill bit instead of a regular bit as they seem to reduce the chance of cracks occurring while drilling.
    I have a set of Rago bed stiffeners I'll be installing soon and that was in the instructions.
  5. Apr 3, 2024 at 11:54 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    If you're worried about a nutsert failure you could use toggle bolts instead to give the D-rings more backside surface area to hold onto. Toggler and E-Z Ancor make some pretty good ones that don't require drilling such a large hole like traditional toggles do plus the anchor stays in place vice a traditional toggle being a one-time use.
  6. Apr 3, 2024 at 1:22 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    You can use 3/16" SS toggle bolts each rated for 65# or 1/4" for 90#.
    If I was going to secure anything of merit I would use SS toggles.
    BlueCrushSC16 likes this.
  7. Apr 4, 2024 at 6:48 AM
    geewizard
    2023 1794 TRD OR
    Regarding toggle bolts, has anyone actually used them in a Toyota composite bed?
  8. Apr 6, 2024 at 5:22 PM
    geewizard
    2023 1794 TRD OR
    I'm going with a threadsert. Thanks for all the replies.
    Black@Blue19 and Hella Krusty like this.
  9. Apr 7, 2024 at 3:58 AM
    Blufin
    Bob
    23 Capstone
    I'm sure someone has,maybe no one here but I'm sure it has been done.
    You had mentioned your going to mount D rings for fastening cans,empty or full I would recommend a secondary nylon strap to compinsate for triple multiplying force of inertia.
    Good luck and post some pic's when you're done.
