Drill dash board tray
Discussion in '2.5 Gen Tundras (2014-2021)' started by DROM3313, Aug 6, 2019.
  1. Aug 6, 2019 at 7:06 PM
    DROM3313
    DROM3313 [OP] New Member
    2019 Silver SR5 TRD Off Road
    none yet just got it
    Does anyone know if I can drill into the dashboard tray on a 2019 SR5 to mount a camera monitor? I don't know what is under the dash at that point and how close it is to the tray. I was just thinking of using 1/2 or 3/4 inch long screws. I figured I could remove the tray and mount the monitor if I could screw it down. Then when I trade it in just put the tray back.... no holes seen!
  2. Aug 6, 2019 at 7:12 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I think you’re right over the head unit without much room to spare.
    Someone will chime in with the skinny soon.
    Tundyfundy and Pinay like this.
  3. Aug 6, 2019 at 7:17 PM
    Welcome from NY.
    They make a mounting bracket that fits in that spot and you can mount the monitor to that.
    Someone will post the link, I've tried to find it.
    NewImprovedRon and Pinay like this.
  4. Aug 6, 2019 at 7:17 PM
    Voyagermike
    Voyagermike New Member
    California
  5. Aug 6, 2019 at 7:20 PM
  6. Aug 6, 2019 at 7:21 PM
    Pinay and Voyagermike[QUOTED] like this.
  7. Aug 6, 2019 at 7:23 PM
    Voyagermike
    California
  8. Aug 6, 2019 at 7:27 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    There’s lots of room to get your hand in there to install a base plate for the ICS mount.
    But just enuf, make sure you don’t drop a nut or screw or washer or else it’s lost. I lost one of the radio mount screws so it’s put back together with three and it’s fine.
  9. Aug 6, 2019 at 7:34 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    3/4 inch may be too long, depending if you have a plate for stabilization, which is a good idea if the camera is to capture off roading time
  10. Aug 6, 2019 at 7:34 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Rago Fab just came out with an awesome dash bracket to mount items to. [​IMG]
  11. Aug 6, 2019 at 7:53 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    I'mma let you finish, but ICS did it better - KanyeWest :p
    @ICS FAB
    HornFrog, Migraine, ICS FAB and 3 others like this.
  12. Aug 6, 2019 at 7:55 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Rago's mount is pretty. But their site does not show how cams or brackets attach to the mount. And their slots and holes dont seem to give you options on attachments.
    Anyone have one and can share with pics how they're using it??
    McMason, TheBeast and Voyagermike like this.
  13. Aug 6, 2019 at 8:47 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    You can also get a hand towel to cover the bottom while installing the nuts. It will help you in not losing any hardware as you're installing
    NewImprovedRon and Pinay[QUOTED] like this.
  14. Aug 6, 2019 at 8:55 PM
    TXTundra2722
    2015 Black Tundra
    I did the same thing:oops::(
  15. Aug 6, 2019 at 9:42 PM
    TheBeast The Beach
    I'm with you here. kinda odd. I watched the YT video and it's not showing what you can attach and how.
    Pinay[QUOTED] likes this.
  16. Aug 7, 2019 at 4:35 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Good suggestion!
    I would still have lost the one screw for radio, dropped it when it was being put back on, but it’s solid with three attaching it.
  17. Aug 7, 2019 at 4:55 AM
    ou77kg
    ou77kg New Member
    Erik
    2016 Tundra CM Platinum 4x4
    Looks like it has 20 threaded nut zerts you can use for attachment points??
  18. Aug 7, 2019 at 5:18 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    TheBeast and porkitt like this.
  19. Aug 7, 2019 at 8:07 AM
    GiantsFanDan
    It looks to be standard mounting points for ram mounts.
  20. Aug 7, 2019 at 8:16 AM
    Stig
    Stig New Member
  21. Aug 7, 2019 at 8:22 AM
    TheBeast The Beach
    Tundyfundy, Voyagermike and Pinay like this.
  22. Aug 7, 2019 at 8:30 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    With the ICS mount I have the option of adding a GoPro or some camera behind the Ram Mount, also adding mounts for phone for me or a passenger. And just the Ram mount on the dash I would want to have a stabilizing support in the head unit under to better support the Ram mount.
  23. Aug 7, 2019 at 10:00 AM
    DROM3313
    Hey guys thanks for all the great input but I think I want to stick with my original plan. I just need to know how much room I have underneath. I like the mount that came with the wireless camera monitor. And I want to be able to remove it and put the tray back when I'm not towing my camper. I'm going similar too what thebeast said but I just want to use screws from the top so I can remove the bracket easily. I have a pro clip for my phone so I don't need to mount anything else.
  24. Aug 7, 2019 at 1:08 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    CB04898C-6B11-44FB-91F6-A3E2CB493C4B.jpg 0CB145F8-5134-4449-A828-A7B21E924AAC.jpg
    I just received the Rago mount today. I was going to get the ics mount and bought the ram mounts for it. One thing I didn’t like about the ics was the inability to add remove mounts without taking off dash. The Rago addressed that and I thought it was more aesthetically pleasing. But you are right about there only being 2 points of contact. But that being said I’m going to buy the ics under part and drill for Rago. 2820E0B7-4D4E-4579-97A1-877595C1FE22.jpg
    TheBeast and Pinay[QUOTED] like this.
  25. Aug 7, 2019 at 4:10 PM
    GiantsFanDan
    Looks great. Post up pics when it's installed.
    TheBeast likes this.
  26. Aug 7, 2019 at 4:12 PM
    GiantsFanDan
  27. Aug 7, 2019 at 5:43 PM
    Stig
    Stig New Member
    Wow, that's a lot of devices on the dash! Didn't realize you weren't the OP when I suggested forgoing the rago mount, since the OP was just looking to mount a monitor.
    Pinay[QUOTED] and ou77kg like this.
  28. Aug 7, 2019 at 5:51 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    At the moment just have the single Ram mount for an ipad during offroading. Just saying i believe i have more options to securing more devices if needed. Using Gaia dor navigation is my goal, and mounting camera for footage as close second.
  29. Aug 7, 2019 at 6:17 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
  30. Aug 7, 2019 at 6:41 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Maybe your tiny, woman hand. :boink:
