Drill bits for slider install
Discussion in 'General Tundra Discussion' started by fisherman951, Apr 11, 2019.
  1. Apr 11, 2019 at 4:19 PM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    just like the tittle states what drill bits are people using or used to install the sliders? I plan on getting a couple step bits and cutting oil so I don’t burn out those bits but what brand and material do you guys recommend?
    Pinay and dcsleeper408 like this.
  2. Apr 11, 2019 at 4:26 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I like step bits and cutting oil or wd40.
    Pinay and Black Wolf like this.
  3. Apr 11, 2019 at 4:40 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Thanks any particular brand u prefer? I have used DeWALT back in the day but I have never drilled in to a car frame so idk
    dcsleeper408[QUOTED] likes this.
  4. Apr 11, 2019 at 4:41 PM
    15whtrd
    15whtrd Mr. Blonde
  5. Apr 11, 2019 at 4:43 PM
    ...or weld it on and be done with it..
    csuviper and dcsleeper408 like this.
  6. Apr 11, 2019 at 4:46 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    If only I knew how to weld.... and had a welder......
  7. Apr 11, 2019 at 4:50 PM
    Heck you're in Riverside. Bet you could find a good welder. Harder to remove should you sell your Tunny for another at some point though.
    dcsleeper408 likes this.
  8. Apr 11, 2019 at 4:59 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Lol. Me and @dcsleeper408 were arguing about this when we were installing our friend’s sliders. He was using a step bit and I was using a straight drill bit. I prefer straight bits. Don’t have to worry about going a step too deep and don’t have to redrill a drilled hole. On metal, I prefer to drill once. A little more difficult but cleaner and better centered.
    dcsleeper408 and Black Wolf like this.
  9. Apr 11, 2019 at 5:02 PM
    The frame isn't that thick anyways. I had to drill a couple holes in the front frame and was surprised how quickly I drilled through. Started with 3/16" pilot hole and then was easy peasy...
    joonbug[QUOTED] likes this.
  10. Apr 11, 2019 at 5:04 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welded is best. No frame holes and stronger. Your never going to remove anyway.
    Pinay, joonbug and Black Wolf like this.
  11. Apr 11, 2019 at 5:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, the frame isn’t too thick. Only difficult part is when you’re drilling on the bottom of the frame upwards. Hard to get leverage and gets pretty tiring. Then having to do 5-7 more really sucks.
  12. Apr 11, 2019 at 5:06 PM
    csuviper
    Broomfield, CO
    Unless it’s not a real rock slider like I have currently and plan to upgrade anyway in the future.
    If true solid rock slider like Victory4x4 or Hefty then weld it.
    Black Wolf likes this.
  13. Apr 11, 2019 at 5:06 PM
    I'm going to convert my beefy high and tight Body Armor rock "steps" into sliders and get them welded permanently to the frame. Saving major $.
  14. Apr 11, 2019 at 5:08 PM
    There's that...
  15. Apr 11, 2019 at 5:08 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Harbor freight ones did the job. Cheap enough to get 2 sets. Use a center punch and a small drill bit to make a guide and then just lube as u drill.
    The carbide stuff is good too, but pricey.
  16. Apr 11, 2019 at 5:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Don’t those break easily? Damn JP. :laugh:
  17. Apr 11, 2019 at 5:14 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    It’s jp... I used the 1 from the same package, smaller bit. And took on the whole driver side. You still need to finish his passenger side lol :rofl:
    Black Wolf and joonbug[QUOTED] like this.
  18. Apr 11, 2019 at 5:16 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    These things are the real deal just ask @jberry813 what he thinks of these sliders
  19. Apr 11, 2019 at 5:22 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Them things are usda pure beef.
  20. Apr 11, 2019 at 5:23 PM
    Yep...real deal...
  21. Apr 11, 2019 at 5:25 PM
    Have to admit that's a few holes to drill...OP....head north and have Joon drill the holes...
    Pinay, fisherman951[OP] and joonbug like this.
  22. Apr 11, 2019 at 5:26 PM
    Beefy steel sliders for dinner!
  23. Apr 11, 2019 at 5:28 PM
    csuviper
    Broomfield, CO
    Def overkill
  24. Apr 11, 2019 at 5:29 PM
    But good overkill....
  25. Apr 11, 2019 at 5:30 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Best served on the rocks.
    Pinay, joonbug and Black Wolf[QUOTED] like this.
  26. Apr 11, 2019 at 5:34 PM
    Quite whitty....
  27. Apr 11, 2019 at 5:37 PM
    csuviper
    Broomfield, CO
    Def adequate
  28. Apr 11, 2019 at 5:41 PM
    Pretty much how I'm going to convert my steps. 4 mounting points will suffice. Each side of my BA's weight is close to 50lbs not including the existing mount brackets. Going to utilize @speckmon 's fab guy in Denver.
    speckmon likes this.
  29. Apr 11, 2019 at 5:47 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    My welders are drooling :welder:
  30. Apr 11, 2019 at 5:51 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Yeah I feel u. My truck is on a 5inch lift so makes plenty of room. I’m even thinking of placing a jack under the drilland putting pressure that way?
    joonbug[QUOTED] and dcsleeper408 like this.
