Dried sap
Discussion in 'Detailing' started by GravityGear, Mar 18, 2019.
  1. Mar 18, 2019 at 1:18 PM
    GravityGear
    GravityGear [OP] Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    So, I've found some dry sap(?) on my paint. They're all dry and cracky. I've tried some APC and citrus based remover, but no luck. Any widely available products that could take care of this? They are about 1" long runs about a 1/8" wide.
  2. Mar 18, 2019 at 1:21 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Try this. It's called Eraser from CarPro. I had some bad staining on my windshield that Windex couldn't get out but this did. May take some elbow grease to rub out, but you should get some good results, imo.
    https://www.amazon.com/gp/product/B00FY1E0HE/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    War Machine likes this.
  3. Mar 18, 2019 at 1:24 PM
    War Machine
    War Machine SSEM # 5 3MW
    Goo Gone will work if it isn’t too bad.
    Black Wolf likes this.
  4. Mar 18, 2019 at 1:41 PM
    Yep...I use Goo Gone to remove sap. On my headlight lenses too.
  5. Mar 18, 2019 at 1:42 PM
    GravityGear
    Aurora, CO
    I tried Goof Off, but I will try Goo Gone.
  6. Mar 18, 2019 at 1:46 PM
    15whtrd
    15whtrd Mr. Blonde
    When it’s dry and crusted on there. You almost have to very carefully scrape what you can off without going down to the paint. Then use Googone on or something like it. At the moment it’s probably just too thick and dry. You could also try soaking a rag with something of your preference and let it sit on the spot.
    NewImprovedRon and Black Wolf like this.
  7. Mar 18, 2019 at 1:47 PM
    Borgs
    Borgs New Member
    PA
    Tar X - unfortunately I had some pine sap ruin my clear coat in a few spots two years ago.
  8. Mar 19, 2019 at 5:25 AM
    briarpatch
    briarpatch New Member
    unscented hand sanitizer
  9. Mar 19, 2019 at 6:08 AM
    WD40
    15whtrd likes this.
  10. Mar 19, 2019 at 6:23 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Try this product. It works for me on sap & tar
    Tempest, Newm and 5.7TRDProm like this.
  11. Mar 19, 2019 at 6:34 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    This product works wonder like magic!!
  12. Mar 19, 2019 at 6:40 AM
    Borgs
    Borgs New Member
    PA
    My sap was dried on after a week in the Adirondacks. I tried many of the products listed and think all worked to varying degree. But my clearcoat was etched and pitted nonetheless. Sap is nasty.
    NUDRAT likes this.
  13. Mar 19, 2019 at 6:44 AM
    GravityGear
    Aurora, CO
    Yeah, I'm expecting etched clearcoat. I'm not SUPER concerned as I run trail in the truck, but OptimumCCR might be an option. It's expensive, but it's much easier than spot painting and feathering with 2k.
    https://optimumcarcare.com/product/optimum-clear-coat-restorer-ccr-
    Much thanks for the products, I'm going to head to the local VatoZone and see what they have. I'll try some WD first.
  14. Mar 29, 2019 at 11:25 AM
    War Machine
    The guys at The Rag Company recommenced this on their podcast the other day.
    One other thing they said works great:
    1)Get some really hot water in a bucket, as hot as you can stand to touch.
    2) Mix in ONR
    3) Soak towels in it, and lay them on the sap for a few minutes.
    They said it will wipe right off after that.
    Faht Nocker likes this.
  15. Mar 29, 2019 at 12:20 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    Isopropyl alcohol
  16. Mar 30, 2019 at 3:07 PM
    GravityGear
    Aurora, CO
    I feel like people are starting to use ONR for everything... Is it snake oil? No. Far from it. It works. But at this point it's like "OH... I broke my leg! Get me the ONR, but first dilute it properly."
    I used the Stoner's Tarminator. The sap got ate.
  17. Mar 30, 2019 at 3:37 PM
    Tundra_Sam
    Tundra_Sam New Member
    Hand sanitizer works great
  18. Mar 31, 2019 at 5:17 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Denatured Alcohol. Isopropyl can be a bit harsh and can leave residue. Denatured burns clean and leaves no residue at all. Used it on my bosses black Ford Escape on pine sap some was on there for the better part of a year and no etching.
  19. Mar 31, 2019 at 5:20 PM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    WD40
    Let it soak. It will take some elbow grease...but it will take it off.
  20. Apr 5, 2019 at 8:32 AM
    Beavis
    Beavis New Member
    South Jersey
    2018 Cement Tundra TRD DoubleCab
    warm water on a wash cloth and let it soak for a while
