Downshift normal?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kameleon, Mar 16, 2019.
  1. Mar 16, 2019 at 5:45 PM
    kameleon
    kameleon [OP] New Member
    Jackson, MS
    2015 Crewmax Limited 5.7 MGM
    I've noticed something that my '15 limited 5.7 crewmax does that my old '12 TSS DC 4.6 didn't do, or at least I never noticed it. When I am slowing down at say a redlight or stop sign the transmission drops down a gear and uses the engine to brake also. Is this normal? This is just while driving around, not in tow/haul mode or anything special.
    Also on my '12 the throttle was super touchy. On my '15 it is not. I thought that is what tundra owners complained about and used things like tuners to fix, the touchy throttle. Did the later years get that fixed or is mine abnormal?
  2. Mar 16, 2019 at 6:06 PM
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    My 18 is very noticeable, seems pretty smart to me but then I came from a 1st gen which didn’t do that
  3. Mar 16, 2019 at 6:08 PM
    kameleon
    Jackson, MS
    Yeah I don't mind at all, just was not sure if it was normal or not. Buying the truck second hand I'm not sure what the previous owner did or didn't do.
  4. Mar 16, 2019 at 6:08 PM
    Ericsopa
    Ericsopa Old man and the sea
    It's normal. Toyota's xmsn ECU incorporates some artificial intelligence programming. Tries to anticipate your intentions. And it knows when you let up on the accelerator and when you apply the brakes.
  5. Mar 16, 2019 at 6:35 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Normal.
    I grew up driving manual transmissions in everything. My last Tacoma was my first automatic, and the way it shifted always bugged me. But I'm actually pretty happy with the way my Tundra shifts.
    15whtrd likes this.
  6. Mar 16, 2019 at 6:40 PM
    kameleon
    Jackson, MS
    Yeah everything I drove was a manual also. I actually like the downshifting but since my '12 didn't do it I wanted to make sure it was normal. My friends '11 doesn't do it either so it must be the '14+ that it changed.
    Ericsopa and 15whtrd like this.
  7. Mar 16, 2019 at 7:56 PM
    Ericsopa
    My '13 does it, or did it, before the D.A.P. tune. A little different now.
  8. Mar 16, 2019 at 7:58 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Normal.
    If your press the tow/haul button the throttle will feel more like your 12'.
  9. Mar 20, 2022 at 9:01 AM
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    My 2018 downshifts at stops. It would seem to me that although it saves brake wear, it must also decrease fuel mileage as engine revs increase.
    Seafury likes this.
  10. Mar 20, 2022 at 12:43 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    This is a valid point and something I keep meaning to discuss here.
    I find my truck in normal mode often downshifts when I come off the gas.
    I can't even coast for shit unless going downhill, even then it sucks.
    You actually have to keep your foot slightly on the gas to even freewheel/coast at all.
    This is very stupid, frustrating, and is wasting fuel for sure.
    This engine braking when you come off the gas should ONLY happen when using the tow/haul button, due to the added weight.
    Toyota got this all wrong imho.
    This is a source of part of our low mpg.
    How much is debatable, but it's a measurable amount I'm sure.
    trevorklat and double cement like this.
