Downhill auto downshift ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by cuaround, May 26, 2021.
  1. May 26, 2021 at 6:40 PM
    cuaround
    cuaround [OP] New Member
    I hope my question makes sense so here it goes: I just purchased a 21 Tundra and noticed that when I leave my house which is all down hill for about a half mile, on occasion if feels like the truck automaticly shifts into a lower gear so I do not have to get on the brakes as much, and I do not know how that is happening. The speed I am traveling is 25-35 and I am in drive not tow/haul. Any info would be greatly appreciated.
    Metro14536 likes this.
  2. May 26, 2021 at 6:43 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Engine breaking completely normal. If you go into the manumatic it will usually just let go...
  3. May 26, 2021 at 6:52 PM
    cuaround
    Thank you for the quick reply Blackdemon, I am curious how it activates? Today it seemed like the truck just rolled much faster. Did not feal any engine braking.
  4. May 26, 2021 at 7:01 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The transmission has sensors in it that can detect the grade you're descending and it has what Toyota calls Artificial Intelligence. I can run my truck down a 6% grade in Drive with the cruise set and at somewhere between 5 and 10 mph over set speed it will down shift and engine braking will increase to slow the vehicle to set speed.
  5. May 26, 2021 at 10:36 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Usually it's because your on a grade and braked, it shouldn't downshift otherwise.
  6. May 27, 2021 at 4:45 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I've noticed that when going down a steep hill, in speeds between 25-50, if I simply coast, it won't always shift down. But if I lightly apply the brakes and then let off, the transmission will shift down. Usually enough to keep my speed constant going down hill. This is on a 2020
    My previous 14 Tacoma V6 would almost always do it on it's own. No matter what I did.
  7. May 27, 2021 at 4:54 AM
    Grade Braking. Don’t use tow/haul mode. To totally disable the grade braking, shift to S mode and shift to S6.
    Wynnded and 316KS_Runner like this.
  8. May 27, 2021 at 5:29 AM
    Willard
    Willard New Member
    2024 F250
    If you lightly touch the brakes on a grade it will usually downshift. It’s been a Toyota thing for as long as I can remember. I had an 06 gs300 that did it as well.
    If you blip the throttle it will upshift.
    Jaypown and Wynnded like this.
