Double Dual USB Ports Installation
Discussion in '2.5 Gen Tundras (2014-2021)' started by crafty762, Oct 27, 2018.
  1. Oct 27, 2018 at 6:31 PM
    crafty762
    crafty762 [OP] New Member
    Bill
    Minneapolis
    2017 Toyota Tundra SR5 TSS Offroad
    Neon floor lighting, LED bed lighting, Google mini, front LED light bar, custom USB power ports
    Several weeks ago, I removed the factory power port in the backseat area and replaced it with two sets of dual USB ports. I re-used the same power and ground wires from the original port. It took some work to expand the hole in the bezel to accommodate the space I needed, but I think it turned out ok. I purchased a Carviya Motorcycle 4-port USB car charger power socket plate from Amazon and trimmed the edges using a lighter to form fit it into the bezel. I used black foam tape to raise the depression in the bezel because the plate was simply too big to fit without having to trim too much off. Also the foam tape has a cool-looking texture which somewhat matches the plastic molding of the truck.
  2. Oct 27, 2018 at 7:20 PM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    I like this!
  3. Oct 27, 2018 at 7:21 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
  4. Oct 27, 2018 at 8:00 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Nice. I like the footwell lights as well, I did mine with blue LEDs as well
  5. Oct 28, 2018 at 3:49 AM
    Mikee.afa
    Mikee.afa New Member
    Humboldt County , CA
    2015 White Platinum Tundra
    Fuel 18in Rims Toyo Open Country A/T 35x325 Smoked headlights/taillights AFE intake TRD Grill Wilwood slotted & drilled Brake Kit(front only) Engine tune & magnaflow exhaust soon too come :)
    Wow, that came out great! Where did you purchase those bright footwell lights ?
  6. Oct 28, 2018 at 8:53 AM
    crafty762
    Bill
    Minneapolis
