Double Cab Subwoofer Box or Baffle
Discussion in '1st Gen Tundras (2000-2006)' started by 2006Tundra, May 18, 2020.
  1. May 18, 2020 at 12:09 PM
    2006Tundra
    2006Tundra [OP] Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Paladin likes this.
  2. May 18, 2020 at 4:38 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    The baffle is nothing more than a piece to mount the subs in to be placed and secured to the compartment. That is exactly what I did on mine. Once you pull the carpet out of that compartment you will see that they are not sealed, so you will have to seal it if you go that route. I used Noico sound deadener to seal up the rear driver side compartment for 2 8" subs.
    I would go with the baffle and sealing up the compartment over the box. By having a full box in there you are taking away a lot of airspace in an already small compartment. By using the baffle and sealing the compartment yourself you maximize the air space for your subs. You also lose an inch of mounting depth with the box (3.5" vs 4.5"). You will most likely have to do a shallow mount sub regardless.
    I was going for the same clean thump as you want, and I am very happy with the 2 8's I have back there.
    2006Tundra[OP] likes this.
