Double cab integrated 3rd brake light install
Discussion in 'Lighting' started by Mountun Goat, Feb 29, 2020.
  1. Feb 29, 2020 at 11:40 PM
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I bought a 48” under tailgate led light strip as it fits the window width. Then I cut the rubber housing off the strip to make it fit into the window seam.
    I cut all the extra buytal out of the window seam to make room for the light strips and silicone.
    Taping the glass and body off helped keep a clean line.
    I laid the window seam half full of silicone, then set the light strip in. Once it was set, I filled the remainder of the seam with more silicone. To ensure perfect silicone placement I used a spray bottle of dish soap water for shaping lube. Just spray the soap onto the silicone and the finger of choice, then glide your finger as needed.
    Lastly, I wired the light into the existing circuit. This light is 5 function so has running(70%), brake, signal’s and reverse.
    I’m pretty happy with the outcome and will need to get some pictures once the truck is outside again.
  2. Mar 1, 2020 at 7:37 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Boerseun, Y0TA PR0 and Black Wolf like this.
  3. Mar 4, 2020 at 8:19 AM
    3rdGenTundraDC
    3rdGenTundraDC New Member
    MGM
    Central Florida
    14 Tundra DC
    305/50/20 Nitto Terra Grappler G2 Stock, stock, stock.
    You're quite brave :fingerscrossed:
    TRD-tv, Boerseun and Mountun Goat[OP] like this.
  4. Mar 4, 2020 at 8:34 AM
    KissMyAxe1
    KissMyAxe1 New Member
    Utah
    2008 Black Tundra SR5 Crewmax
    That looks good! I want to do something similar with the bed rack I have in mind, attaching something like this to the back of the rack.
    Mountun Goat[OP] likes this.
  5. Mar 4, 2020 at 11:28 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks, figured I’d try something different:)
    Boerseun likes this.
  6. Mar 4, 2020 at 11:32 AM
    That is cool.
  7. Mar 4, 2020 at 1:54 PM
    102dalz
    102dalz New Member
    Andy
    2017 Tundra CrewMax White
    None
    How did you wire it? Straight to the trailer wiring in/outlet?
  8. Mar 4, 2020 at 3:16 PM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    The night shots look killer. Some modern integration without the bulk. I like it.
  9. Mar 4, 2020 at 5:59 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yeah you bet, I ran the wires down between cab and box, then down the frame and into the trailer wiring.
  10. Mar 4, 2020 at 5:59 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks I do too :)
  11. Mar 4, 2020 at 6:08 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Hindsight, next time I would spray paint the wiring flat black, this way the you wouldn’t see the one white wire beside the glass. :annoyed:
