Doors won't unlock with fob
Discussion in '1st Gen Tundras (2000-2006)' started by HoganJr, Apr 2, 2024.
  1. Apr 2, 2024 at 3:15 PM
    HoganJr
    HoganJr [OP] New Member
    I've got an '03 Tundra Access Cab. Recently I started having this problem where the doors will lock with the fob, but will not unlock with the fob. I thought maybe this is a common problem and somebody knows how to diagnose and fix it. And maybe some tricks and tips. I've done a little research, but I want to hopefully be confident what the problem is before I start pulling doors apart.
  2. Apr 2, 2024 at 3:20 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I had that happen before and I had to use it 2 ft away for it to work. A new battery fixed that issue.
    Black Wolf likes this.
  3. Apr 2, 2024 at 3:23 PM
    Yep, new battery. If that doesn't work......new fob.
  4. Apr 2, 2024 at 3:59 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I found (probably by a post on this board) that if I hold the fob against my cheek that the door will open when it otherwise won't.
  5. Apr 2, 2024 at 4:07 PM
    HoganJr
    I replaced the battery right away and tried the spare fob. Same results. That’s what made me think the problem is in the door.
    How do you get a new fob?
  6. Apr 2, 2024 at 7:39 PM
    meeseeks55
    meeseeks55 New Member
    2002 SR5 Access Cab 3.4L V6
    Not sure if this would apply to this particular year of vehicle, but sometimes when programming a fob there is a sequence of things you have to follow to get the fob paired to that particular vehicle. Maybe see if there is a sequence with your vehicle and try it with your current fobs.
    FrenchToasty likes this.
  7. Apr 3, 2024 at 7:17 AM
    Before getting any further, can you please post a picture of your fob so we know which system we're advising you on? RS3000, RS3200, afermarket?
  8. Apr 6, 2024 at 1:30 PM
    HoganJr
    This is what they look likeE65B2DEF-28CE-4677-9BC7-E88BDB4E17E5.jpg32440A48-A87E-47F7-974A-D5582ED5EA66.jpg
  9. Apr 6, 2024 at 1:43 PM
    Jack McCarthy
    Bill
    North of Boston
    shifty` likes this.
  10. Apr 6, 2024 at 2:26 PM
    Looks like you're using the RS3200 TVIP security on the truck. Programming instructions are here for Reg Cab, Acc Cab, and some Db Cab.
    I'd buy a different remote and see if that gets you sorted; if not, you've now got a spare remote. Bill just gave the link, you basically need the key fob with FCC ID "BAB237131-056". Searching for the phrase BAB237131-056 anywhere on the internet will net you a replacement. The hardest part is programming it - it normally takes me 2-3 tries before I get the order/timing of steps correct, and I've done it half a dozen times on this truck already. Doesn't seem to get any easier with repitition, so keep trying the exact instructions in the linked document.
  11. Apr 6, 2024 at 4:56 PM
    HoganJr
    Thank you. I’ll report back
