Doors Auto Unlock
Discussion in '1st Gen Tundras (2000-2006)' started by Ken4x2, Jul 25, 2021.
  1. Jul 25, 2021 at 8:02 PM
    Ken4x2
    Ken4x2 [OP] New Member
    Kenton
    2000 Toyota Tundra 4x2 v8 access cab
    Straight piped Lift kit Led light bars Radio
    Hello I needed some help finding the problem with my truck it’s a 2000 Toyota Tundra access cab. The doors will unlock themselves wether the key is in the ignition or not and it’s not the quick unlock sometimes it’s unlock 5 seconds later other it’s 2 minutes. Also while driving highway speeds above 55 the temperature raises but driving in the city (50 and lower it’s fine.
  2. Jul 25, 2021 at 8:15 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Does your truck have the factory alarm system installed. Easy way to check is on the left side next to the steering column is there a black rectangle that says security and has a light on it? Or do you have an aftermarket alarm installed or anything?
  3. Jul 25, 2021 at 8:19 PM
    Ken4x2
    Kenton
    It does have a red light yes but I never got a fob for it when I bought it I’ve had it just over a year and it just started doing this
  4. Jul 25, 2021 at 8:30 PM
    NickB_01TRD
    Nick
    KY
    Does it usually lock/unlock when you start/turn off the truck? I think the easiest thing to try first is a reset by unhooking the battery for a little while then hooking it back up.
  5. Jul 26, 2021 at 6:37 AM
    Welcome to the forum! Pics are semi-mandatory btw. The unlock door feature can happen even without the factory alarm installed. Mine will auto unlock if you try to lock the drivers door from the inside while the door is open. I guess to keep you from locking your keys in the truck? Most Toyotas I've had have this feature. Maybe that feature is malfunctioning. Sounds like you have a second issue with overheating as well? more info would help with that.
