Door will not LOCK - Fob, switch or manually??
Discussion in '2nd Gen Tundras (2007-2013)' started by LiftMeUp, Jun 30, 2023.
  1. Jun 30, 2023 at 6:42 AM
    LiftMeUp
    LiftMeUp [OP] New Member
    I have '13 Tundra Crew Max. My driver side rear door will not lock. If I use the fob or the controls on the front driver or passenger door you will hear the doors lock but then that driver side rear door will immediately unlock. I was thinking actuator is bad. But the odd thing is I cannot manually lock either. The flip switch by the door handle is like almost jammed in the middle so cannot flip to unlock or lock. ANY IDEAS???
    Thanks!!!
  2. Jun 30, 2023 at 6:56 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Not sure the cause but you will likely need to take off the interior door panel to review the linkage between the various pieces. Does it actually move at all with the actuator or move and then move back?
    LiftMeUp[OP] likes this.
  3. Jun 30, 2023 at 7:29 AM
    LiftMeUp
    This happened last night so going to have to look today and see. You can definitely hear the locking noise and then 1 second later hear it unlock. Now whether it's actually moving or not I'll have to look. The confusing part is the flip switch by the door handle not moving. I called the dealership and he was that was weird that the manual lock didn't work, thought maybe something was jammed inside the panel. May take panel off this weekend and see if there is anything obvious.
    Dsptundra[QUOTED] likes this.
  4. Jun 30, 2023 at 8:05 AM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
  5. Jun 30, 2023 at 8:16 AM
    LiftMeUp
    Patch999[QUOTED] likes this.
