Door weather stripping squeak.
Discussion in '3rd Gen Tundras (2022+)' started by murtro, Nov 5, 2022.
  1. Nov 5, 2022 at 8:48 AM
    murtro
    murtro [OP] Life is unpredictable. Eat dessert first!
    Alberta
    I get a sound (more of a squeak than a rattle) every time I hit a minor bump in the road. I think it sounds like the weather stripping rubbing on both the drivers and passenger side? Anyone else notice this?
    Is there an easy fix?
  2. Nov 5, 2022 at 9:42 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Is it a 22? Which doors or all doors. My 22 had passenger door doing same thing and it took a while but I finally got it fixed. Dealer replaced all moldings and nothing helped. Mine turned out to be the door just wasn’t tight enough causing the upper window from to cause a friction, squeaking noise. A field tech from Toyota came for a ride and had dealer adjust the door from the latch mechanism from the door itself. Problem finally solved!!!
    kstateskier and murtro[OP] like this.
  3. Nov 5, 2022 at 11:56 AM
    murtro
    Alberta
    Yes 22 Platinum. This sounds like the issue. Thanks!:cheers:
  4. Dec 18, 2022 at 10:22 AM
    Robert7810
    Robert7810 New Member
    Robert
    22 -1794 Tundra
    I had the same noise, took to dealer and they thought was inside the door and ordered some parts, I still didn’t thinks that was it so I sprayed all my door rubber seals with spray silicone and the noise is gone. Going to call and cancel that part order. Guess keep a can close by if it starts again.
  5. Dec 24, 2022 at 7:53 AM
    graf_von_tundra
    graf_von_tundra Not so new
    Central Texas
    2023 Tundra 1794 4x4 Black
    I had the same issue and used cornstarch sprinkled on a rag to lightly dust the seals. Worked perfectly besides now looking a little dusty.
  6. Dec 24, 2022 at 7:59 AM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I have a '23 1794, no squeak, but I'm surprised how much force it takes to close the front doors. We have a 2022 Venza and that door closes much easier. On the Tundra if I don't give it a push harder than I've used on any other vehicle it will not fully latch. It's not crazy hard, but took a while to get used to as I've never been a fan of a hard slam on car doors...just seems like a hard slam is asking for long term problem of some sort. I therefore suspect that Toyota has either beefed up the door weather stripping to reduce the wind noise problem, or adjusted door latches to require the door to be a bit more closed for the same reason, or both. This is consistent with adjusting the door closed position to remove a squeak.
