Door speakers not working after changing head unit
Discussion in 'Audio & Video' started by tAcomaPueblo, Jul 13, 2019.
  1. Jul 13, 2019 at 8:16 AM
    tAcomaPueblo
    tAcomaPueblo [OP] New Member
    Tampa Bay
    2014 SR5 TRD OR CM 4x4
    Hey all,
    I changed the head unit on my 2014 Tundra non-JBL w/ center speaker and now only the top 3 speakers in the dash and the rear door tweeters work. None of the 4 door speakers do.
    The wiring is the same from my 2017 tundra. I looked at crutchfield and when I add it all to the cart its the exact same harnesses and cables I have. All wires frim head unit match to correct door speakers but maybe something is different in the wiring of the tundras that habe the extra speakers on the dash?
    Anyone have any advice? I plugged OEM head unit back in and it works great.
  2. Jul 17, 2019 at 5:05 AM
    865AllAmerican
    865AllAmerican New Member
    Josh
    Vol Country - Knox-Vegas, TN
    2015 Tunda TRD Pro
    That sucks!! I'm getting ready to do the same thing to my 15 CM non-JBL w/ center speaker. If you don't get a good answer and haven't figured it out by the weekend, I'll give you feedback on my install. If it helps???
  3. Jul 17, 2019 at 5:47 AM
    Cfincke
    San Antonio
  4. Jul 17, 2019 at 8:19 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Yep, I believe the speakers that are working are powered by the HU. All the speakers that aren't working are powered by the OEM amp which should still be present on non JBL models. You probably just missed the amp remote or 'turn on' wire on your harness. Usually a blue or blue w/ white stripe wire. Which harness are you running?
    tAcomaPueblo[OP] likes this.
  5. Jul 17, 2019 at 9:09 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, it is the amp under the seat. I went opposite route. Left OEM HU but ditched the amp and speakers and added sub. Big time improvement . You can actually hear the tweeters now.
  6. Jul 17, 2019 at 3:26 PM
    tAcomaPueblo
    Tampa Bay
    Oh man if that is why my head unit isnt playing from the door I'm buying you a round of drinks. Its been blowing my mind that it isn't working with the correct harness. If only I didnt just have surgery on my arm a few weeks who and then two days ago throw out my back installing my pop & lock... I can't wait do try this.
  7. Jul 18, 2019 at 12:11 PM
    801Tundra
    UTAH
